Pm8 ecu
Old Mar 18, 2012 | 07:19 PM
50stanger's Avatar
Default Pm8 ecu
Hi will a pm8 ecu work for a mpfi swap and will the pin outs you all show be the same?
Old Mar 19, 2012 | 06:48 AM
jlicrx's Avatar
Default Re: Pm8 ecu
will it work? the answer is yes (pinouts are essentially the same)
will it work well? the answer is no
the PM8 is the MPFI ECU for the HF engine and as such it has fuel and ignition maps designed specifically for the HF and won't work well with any engine other than the HF - has fuel cut-off (rev limiter) at 5600 rpm, which is way too low for anything other than the HF - the PM8 will also be looking for a EGR valve and when it doesn't find one, you get a Check Engine Light
Sampsonite987
10
Jan 10, 2020 04:08 AM
hucoreyCRX
Jul 30, 2008 05:03 AM
Tyson
Aug 10, 2004 12:50 PM
Ronin Panda
Jul 12, 2003 12:31 PM
IamVtec
Aug 29, 2002 09:58 PM
