94 civic no power
Old Mar 18, 2012 | 06:42 PM
hate!'s Avatar
Default 94 civic no power
i was driving my car today. stopped some where and shut it off. then when i got back in and tryed to start it, it cranked for a second and then went dead. i have power at the battery but everything from there has nothing. checked my fuses in the under hood fusebox and couldnt find anything. replaced my ecu fuse, and my battery terminal, still nothing. dash lights dont come on and fuel pump doesnt prime, so i doubt its the main relay. tried to jump the battery and it wouldnt draW power from the other vehicle. i dont have my voltage tester and the car is sitting in a parking lot so its hard for me to just go diagnose ****. i figure its either my battery or my ecu. anyone have any suggestions?
Old Mar 18, 2012 | 07:02 PM
hannslebo's Avatar
Default Re: 94 civic no power
I'd try a known good main relay before anything else, assuming you open the ECU and don't see any obvious signs of damage. Also clean and tighten the G101 ground wire attached to the thermostat housing. And check the other grounds as well.
Old Mar 18, 2012 | 07:09 PM
hate!'s Avatar
yeah i took the ecu cover off and checked it and didnt see anything noticable. yeah ill try cleaning that ground, im gonna try another battery in it and see if that helps. i had a poor connection at my battery so i dont think it was charging very well, but i dont see why it would just completely go out like that.
Old Mar 18, 2012 | 09:39 PM
hate!'s Avatar
tried another battery and still nothing. from searching im thinking it could be my ignition switch? my headlights and tail lights dont come on either if that helps.
Old Mar 18, 2012 | 11:27 PM
jbpnoman's Avatar
Why are you so thoroughly convinced it isn't your main relay? You said the fuel pump doesn't prime, that's indicator #1 of a fried main relay. They're cheap - replace it and see what happens.
Old Mar 19, 2012 | 08:42 AM
hate!'s Avatar
well ive had main relay issues before, but they never caused my entire car to not have power. usually just in the fuel pump circuit.
Old Apr 21, 2013 | 08:04 AM
ruben6805's Avatar
Did you ever get this problem resolved?
warmeister
Honda Civic (2001 - 2005)
Mar 6, 2019 10:58 AM
GPC91
May 23, 2013 09:15 AM
jrp355
Oct 19, 2011 07:49 AM
95B16-T
Oct 14, 2010 12:10 PM
extensioncordy
34
Jan 30, 2007 03:38 PM
