Low hanging exhaust..
Alright so sadly before the winter i thought i was good backing up into this slightly slanted garage, and my exhaust got caught on the cement and pulled my whole exhaust towards the front of the car
I ended up pulling it back towards the back of the car and everything still fits fine although there is still a slight bend in the exhaust. I am going quite low in the near future and i know this is going to cause some issues as DA's unerbodys hang pretty low as it is.
Does anybody know what the simplest way of fixing this issue?
it has never been like this. When you are far away from the car you can notice it hanging extra low which was caused when the whole exhaust got pulled forwards after the flex pipe got caught.
must have bent the manifold. not sure if that can be fixed cost effectively. check where it bolts to the head. make sure you didn't pull any threads. take a close look at the manifold. see if you can spot where it might be bent
on a side note, just saw your build thread. car looks great otherwise!
Yeah it would work I've done it on a few cars. I just used a torch to hear it up till it glows orange jack it up a pump or two heat it again and another few pumps. Always go a little higher then where you want it becuase when you let the jack down the pipe will fall a bit too
Make sure to put the jack and 2x4 on the flange with the flex pipe and heat it from the bend and a few inches towards the flange so it will be re bending the original bend
Well, i couldn't dig up the torch, but i decided just to jack it up and leave it like that overnight. If that doesn't do it i will keep looking for the torch and hopefully the heat will do the trick.
heres a picture if you guys are curious haha
The only thing with doing that is your putting stress on the manifold bolts I would be careful doing it without heat. I know how it is to want it done yesterday so you try other ways but be careful you don't mess something else up in the process.
Yea I took that in to consideration, I checked all the bolts and they seemed to be fine. But I guess leaving it like that over night might but some stress on them. I will use heat tonight and let yoU know how it goes
So found the propane torch, and just as i suspected it does not have the enough heat to heat the exhaust up.
Any other ideas on what to do besides tearing out my whole down pipe and replacing it? ( turbo manifold )
i cannot drive the car like this as it is almost scratching the ground when i am lowered
Origin
Aug 29, 2004 03:45 PM
