94 accord stalling issues
Old Mar 18, 2012 | 11:30 AM
JAGRBOMBS's Avatar
Icon6 94 accord stalling issues
94 accord ex 4 cylinder automatic. car has 340000kms on it and the motor runs like a top. However it randomly stalls in all different scenarios. some days i can drive over 100kms and it wont do it. other days i get around the block and it craps out. I have changed the distributor, spark plugs, wires and air filter. havent changed the fuel filter yet as im trying to find tips on getting that out as well. the fuel pump turns on every time i start the car and when it does stall, it doesnt hesitate or anything it just literally shuts off, and all the dash lights remain on. Any help is greatly appreciated
Old Mar 18, 2012 | 02:45 PM
the_penetrator's Avatar
Default Re: 94 accord stalling issues
check the ground for your fuel injectors its on the intake manifold on the right side bolted to the intake manifold.................... also could be the ignition switch
Old Mar 18, 2012 | 04:13 PM
JAGRBOMBS's Avatar
thanks i check that tomorrow. i have also been told it could possibly be the fuel pump relay.
Old Mar 19, 2012 | 09:41 AM
JAGRBOMBS's Avatar
Icon6 Re: 94 accord stalling issues
So I checked the ground and it looks fine. Also there is an auto-start installed on the car. I checked the ignition conections on that and they were good as well. I also shut the auto-start off to try and eliminate that from the problem but the car still stalled. How would I go about testing the ignition? The problem is getting worse as in before it would stall once and then it would be goI'd. Now it continues to stall. Today it stalled 4 times on my way to my buddies place to check the ground out. My buddy turned the ignition on and off a bunch of times and then it started and he was able to drive the car to his place no problem. I have tried that before and sometimes it works, sometimes it doesn't
Appreciate any and all suggestions
dslatet455
Mar 15, 2018 10:18 PM
Waynecal19
Jun 7, 2016 01:07 PM
decklyn18
May 18, 2012 03:13 PM
Dizzle89
Oct 25, 2008 05:04 AM
regs
Dec 27, 2004 05:05 PM
