dart gsr
I m an owner of a fully build - turbocharged honda.
The block is coming from Dart and the head is a ported fully opened GSR.
The engine is powered from a Greddy T-78 turbo kit and has only 5000 Klm on it.
My problem is that I have somewhere water leakage. For every 100 klms I m losing about 400ml of water and the thing is that is passing it inside the Cylinders. I have checked the engine block and the head twice for leakage test and nothing showed up. Furthermore I have changed flanges 4 times and still I see water passing in the cylinder.
check the exhaust ports and intake ports to make sure the head wasnt ported too much which can cause it to lose water. i knew somebody who it happened too so im just going off of personal expierence with his car. check the sleeves really good or have it checked by a machine shop if you could.
