92-96 Prelude Partout
Pics are below. Prices as listed befor shipping or paypal unless agreed otherwise. the car will be pulled apart on saturday the 31st, everything will be shipped that day as well
6785683113 - Clayton
Located In Dacula, Ga
Axles - 40 each
Spindles with calipers and brake lines - 75 each
Subframe - 125
Front swaybar with hardware - 50
Front lower control arms - 30 ech
manual conversion - 150
Transmission h23/Si - 450
Machine shop fresh h23 Head - with cams 450
Vlave Cover H23 - 100
Headlamp passenger side - 100
ABS pump - 250
Core Support - 125
Cluster 75 (non EL) - 80
Warning Light Gauges - 50
Corner Markers for front - 30 each or 100 for set, all 4 perfect
Sunroof - 125 (no rust works perfect)
Seats - 150 for the front pair
Fender drivers only - 50
Steering column with ignition/wheel - 125
Bumper Support front - 75
Passenger side grill - 30
EVERYTHING WILL BE SCRAPPED AFTER SATURDAY.
There is also a b18a1 bottom end and complete h23 botom end. Make offer.
Axles - 40 each
Subframe - 125
ABS pump - 250
Core Support - 125
