98 INTEGRA LS A/C PROBLEMS!!!
Old Mar 18, 2012 | 02:09 AM
JDMFLUSH1's Avatar
Default 98 INTEGRA LS A/C PROBLEMS!!!
SO I BOUGHT A 98 LS FROM THE ORIGINAL OWNER. THE ONLY PROBLEM IS THAT 1 AND 2 ON THE A/C ONLY BLOW WHEN THE CAR IS MOVING... AND THE VENTS STAY OPEN EVEN WHEN THE CLIMATE CONTROLE IS SET TO OFF... WHAT CAN THIS BE????
Old Mar 18, 2012 | 03:11 PM
tegman97's Avatar
Default Re: 98 INTEGRA LS A/C PROBLEMS!!!
Are you sure the blower is actually working on speeds 1 and 2 and that it's not just air being moved into the cabin from the car moving? If the blower works on some speeds but not others it's probably the blower motor resistor. I work in a shop and that's almost always the problem. And the only way to stop air moving in through the vents is by pushing the recirculate button
Also, the caps lock key is right next to the A key...
Old Mar 19, 2012 | 07:42 AM
JDMFLUSH1's Avatar
on speeds 1 and 2 and also when its set to off i think it works with ram air (air from the motion of the car)...
Old Mar 19, 2012 | 08:34 AM
tegman97's Avatar
Hmmm... I can't imagine why it would work only when the car is in motion. For how easy it is I'd just go to autozone and pick up a blower motor resistor and try it. If it doesn't work you can just return it.
Old Mar 24, 2012 | 12:18 PM
JDMFLUSH1's Avatar
i tryed what u said about pressing the recirculate button and that stopped the air from coming in... its not the climate controle is it? i was thinkin it could be the blower motor..
Old Mar 24, 2012 | 12:19 PM
JDMFLUSH1's Avatar
anyone know where i could find this write up?
Old Mar 24, 2012 | 12:56 PM
fcm's Avatar
fcm
Old Fart
You will need to check the blower motor, it's easy.
In most cases if the blower resistor is the problem the blower will work on fastest speed, [speed 4].
At the blower motor plug, [bottom of the blower motor] test for power, [blue/white lead of 2pin plug] the ign. switch must be on.
If there is power on the blue/white, use a jumper lead to supply a ground directly to the other lead in the plug, [blue/black] if blower works the problem is not the blower motor, blower motor relay or a fuse, it may still be the resistor and it will need to be checked, [bypassed]. 94
Old Mar 26, 2012 | 03:41 PM
JDMFLUSH1's Avatar
HOW DO I CHANGE THE BLOWER RESISTOR?..... I DONT EVEN KNOW WHAT THAT IS OR WHERE ITS LOCATED. WHERES THE RESISTOR?
THANK YOU DUDE!!
Old Mar 26, 2012 | 05:02 PM
tegman97's Avatar
You should follow the steps listed by fcm first. But this is behind the glove box
And here's a picture of the blower motor, just in case it'll help you:
If you'd like I can post a flowchart for diagnosing blower motor problems but fcm's post is all you need. If it was me I'd just change the resistor because it's common and easy to do and if it doesn't work you can always take it back
Old Mar 26, 2012 | 05:12 PM
Jyee986's Avatar
Is it a lot of air coming through even when its turned off or just a little?
Old Mar 26, 2012 | 07:38 PM
fcm's Avatar
fcm
Old Fart
THANK YOU DUDE!!
Why would you change it untill you at least knew it may be the problem, the problem can just as easly be the blower motor, blower motor relay or just wiring, like a poor dash harness ground.
It costs you nothing and saves you time to check first and then go and buy the defective part, if there is one.94
Old Mar 27, 2012 | 05:24 AM
el crapitan's Avatar
could also be the switch.
but yes, regardless, confirm first. then replace.
Old Apr 5, 2012 | 04:24 PM
JDMFLUSH1's Avatar
I already checked the relay... and if the blower turns on when i put the a/c to 3 oand 4 then the swith work.. right?
Old Apr 5, 2012 | 04:28 PM
JDMFLUSH1's Avatar
that looks for like the a/c compresor...maybe something with labels.... i was looking for the fcm at the auot parts store but no luck...
thank you!!!
Old Apr 5, 2012 | 04:33 PM
JDMFLUSH1's Avatar
every time i open this thread the images change on this post u replied..
Old Apr 6, 2012 | 08:45 AM
no. the switch contacts for setting 1 and 2 could be bad/poor. each setting has a separate contact in the switch.
and yea, those pics are acting up. as i type this, i'm scrolling down and that pic is coming up as srs components diagram. but in the thread it shows a circuit diagram
Old Apr 10, 2012 | 11:18 AM
JDMFLUSH1's Avatar
if i could just locate the blower motor resistor i would try that... is there a fcm on this forum?
Old Apr 10, 2012 | 11:57 AM
fcm's Avatar
fcm
Old Fart
Blower resistor is mounted to the top of the blower housing, pull the glove box to access it.
#5 is the resistor... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal, it mounts into the case directly below it, right in front of the recirc door. 92
Old Apr 26, 2012 | 12:52 PM
JDMFLUSH1's Avatar
THANKYOU!!!! PROBLEM FIXED!!!!
USMarine
Oct 29, 2008 11:49 AM
PINKS
21
Dec 21, 2006 01:46 PM
charles1
Dec 8, 2005 01:24 PM
Seedc2
Mar 22, 2002 02:41 PM
