93 civic mini me - injector #2 won't pulse fuel
ok so just got my mini me going. Here's the issue. I have fuel,spark on all cylinders but cylinder 2. I have voltage at the harness clip but the injector is not shooting fuel into the cylinder. I have swaped out fuel injectors with the cylinder 1's injector. I also swapped the injector clips between 1 and 2. I have also an automatic P06 ecu i swapped over and tried that,same effect.Im lost can anyone help?
also set timing multiple times. had to redue the timing cause it was off a tooth or two but i wouldn' think that would casue the injecotr not to fire into the cylinder
