MO 2000 mustang gt nicely modded ft
hi everyone I'm wanting to get back into imports will trade for modded Honda prefer boosted or wrx or may trade for others let me know what u have thanks 2000 mustang gt please keep negative comments to yourself thanks103,000 miles Below is all the info on it. It is a 2000 Mustang gt with 103,XXX mileson it but only around 20,xxx on thewhole drivetrain,motor,tranmission, rearend. Here are the mods.vis carbon fiber Cowl hood also have stock gt hood carbon fiber dress up kit in the interior Romeo Block Windsor heads that are ported and polished Trickflow track heat intake mainifold Accufab 75mm Throttle Body Msd ignition coils with ngk tr6 plugs gaped at .32 Anderson PMS fuel/timing system. Stage 2 comp cams(.545 intake lift/.495 exhaust lift) 03/04 cobra forged crank. Pypes Long Tube Headers Pypes H-Pipe Pypes M-55 mufflers everything is all 2.5 all the way back Promotion Built Transmission Tr3650 Underdrivepullies forged rods and pistons King Cobra Clutch Aluminum flywheel Aluminum driveshaft Jegs Drive shaft safty loop 8.8 ratcheting locker 3:73 gears Trickflow differental cover Strang Street/Strip Axles Tubuler upper and lower control arms All enlarged fuel lines from the tank to the front of the car. SLP Line lock Drilled and Slotted rotors up front with new performance friction pads. Tubular front impact bar for a intercooler will fit. Morsoe coolant tank. 40lb injectors with matching mafsensor Welded in subframe connectors Strang rear struts fully adjustable. D&D tubulark member with polyurethane motor mounts D&D tubular A-Arms Qa1 coil-over kit in the front. Eibach Drag Lanch Springs in the rear. Battery relocated to the trunk. Pull shut off in the rear with a detachable rod to go out of the trunk. Full mb quart speakers in the whole car. Built in subwoofer box ported with a 10' alpine type s subwoofer Panasonic headunit with ipod hookup Kicker amp to power it all with equalizers under the rear seats All power wire is streetwire. Has autometer gauges one is boost and the other is fuel pressure Innovate wide band with logging software hurst shifter. 35th Anniversery Gaugecluster 10th anniversey floor mats 10th anniversery wheels with all brand new tires(wheels are only 3 month sold) Grey leather seats(no power seats for weight reduction) sequential tail lights Professional tinted tail lights (they are glossy and the gloss matches the rest of the paint) Complete shaved trunk lid with spoiler holes filled and all other holes filled. New headlights 10k HID Headlights Mach 1 chin spoiler Mach 1 Grilldelete 20% tinted windows Heat and Ac work perfect. Interior is all in very good condition(driver seat has a very small tear) The car has a very small dent about the size of a golf ball.( i had a dentless repair shop look at it and said about 100-200 to fix it) This car is a very clean car and gets washed every 2 days and waxed once a week and has ZERO rust
Turboed00EM1
Aug 4, 2006 12:00 PM
