Cigarette lighter doesn't work
Old Mar 16, 2012 | 02:22 PM
PhantomPharter's Avatar
Default Cigarette lighter doesn't work
So, I replaced the fuse. Did nothing. Just pulled the piece under the climate control off and come to find out it's not plugged in. But I can't find anything to plug it in to. Just a loose black wire and a loose yellow wire. I'm thinking the previous owners, along with butchering most other wires, may have pulled it out of the harness? Is there a diagram that shows which one it plugs into? I googled that **** to no avail...
Thanks
Old Mar 16, 2012 | 03:31 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Cigarette lighter doesn't work
Pics please. So we can tell you what you're missing.
Old Mar 16, 2012 | 04:33 PM
do these suffice?
Old Mar 16, 2012 | 04:53 PM
The Grumpiest
What about the back of the actual power receptacle?
Old Mar 16, 2012 | 05:56 PM
angrysmileyface's Avatar
There should be a small harness connected to the cigarette lighter receptical that connects back to another harness (It has a light bulb and a the power connector for the lighter) This is according to the Civic Service Manual PDF for 92-95. Is the 96-00 Different?
Old Mar 16, 2012 | 06:15 PM
Axatax's Avatar
On this model year, that sub harness is present only if there is an actual ashtray installed (not just lighter socket).
You're missing the black plug on the yellow/black wire that goes to the lighter socket. You can just use two quick disconnect/spade type terminals from RadioShack. They will fit perfectly onto the lighter socket. Yellow wire to center pin on the socket.
And I wouldn't actually use this for a lighter. The yellow/black wires are something like 22AWG dental floss. The actual ashtray that comes with a lighter has beefier wire that home runs back to the fuse box.
willskillz805
Aug 7, 2009 05:16 PM
O RLY
Nov 3, 2005 07:30 AM
O RLY
Audio / Security / Video
CoolKat
May 2, 2003 11:22 AM
