k24a2 ecu without the drive by wire
Old Mar 16, 2012 | 10:35 AM
tstyles06's Avatar
Default k24a2 ecu without the drive by wire
whats good ht, im in the process of getting a build started as follows:
k24a4 block(element)
k24a2 head(tsx, might i add im the luckest on ebay! great condition all sensors $260)
rsx type-s oil pump(i know the whole chain guide spill)
rsx type-s intake manifold
eagle rods
crv pistons or aftermarket
every thing else stock or supported mods.
note: will be running crv pistons for the piston to valve clearance issue, am i right about doing this. do i have the option of running tsx pistons? Yes, the head will be resurfaced.
My main problem is the damn ecu. can i get away with running the tsx ecu and just run a crv throttle body. i was thinkin about k20tuned.com doc ecu but why not get the map thats closest to the motor, which would be a stock tsx ecu. I was looking at a aem fic $325 for light boost(400hp)(KPRO IS NOT AN OPTION!, when im finally set for high levels of boost and I got the money then i'll look towards that route)
thanks for the input and advice.
Old Mar 17, 2012 | 01:46 PM
tstyles06's Avatar
Default Re: k24a2 ecu without the drive by wire
thanks guys,lol im going to jus run the k20tuned doc ecu for now.
Old Apr 19, 2012 | 10:34 PM
switchfoot84's Avatar
How does the k24 run with the doc ecu? Making good power? Any issues?
!k-24 coupe!
Apr 3, 2010 11:00 AM
(EF)Edgar
Audio / Security / Video
Feb 15, 2009 04:12 PM
Dirty_SL8
Honda Civic (2006 - 2015)
Nov 24, 2008 06:07 PM
cmdr430
Jan 6, 2004 03:54 PM
