Starting issues
Have a 92 accord that is getting power to everything with a full charge on battery, however when trying to start car does nothing. Does not even attempt to crank. The previous owner messed with the wiring and left quite a mess. There is a relay under dash that has had several wires come loose form the disconnects. Just need to know which color wires need to be plugged back into which spots on relay...
Also having issue with drivers side door. Door will unlock but cannot open from inside or out. Need to know how to access door lock mechanism without open door. And what might be needed to repear...
pauwo
Feb 24, 2012 07:33 PM
95sihb
Jan 3, 2003 08:27 PM
