clutch in brakes in rpms go up
Old Mar 15, 2012 | 05:17 PM
KINGVEM^^ED6's Avatar
Default clutch in brakes in rpms go up
When I have the clutch pedal in and foot on the brakes my rpms go up
Check valve is working
Brake booster 2years old
Any ideas
Old Mar 15, 2012 | 05:44 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: clutch in brakes in rpms go up
High possibility the brake booster failed. It could also be your electrical system. Have you checked for vacuum leaks or your charging system?
Old Mar 15, 2012 | 05:46 PM
Ill check vac leaks
And charging systems good just had everything checked
Old Mar 17, 2012 | 10:40 PM
justinschmidt's Avatar
How high does the idle go up when you do this? It should slightly raise with the sudden change in vacuum.
Old Mar 17, 2012 | 10:55 PM
88HATCH(:'s Avatar
mine does the same thing .. mine is due to a bad booster .
Old Mar 17, 2012 | 11:01 PM
I lost a nut on the brake booster so it was moving tje pedal.assembly
Put a new new tightened the other three problem solved
Old Mar 19, 2012 | 01:02 PM
DO IT ON ALL FOURS
The master does it again! (I was talking about me... ) Odd, problem to have though - it's not good when your nuts fall off.
Randysi
26
Jul 26, 2012 03:28 AM
Ueichi
Feb 25, 2011 02:25 PM
tylergwesterhold
Feb 7, 2009 06:11 AM
pythoner
Suspension & Brakes
Sep 11, 2008 05:06 PM
turbo-lude
Jul 1, 2006 08:16 PM
