non abs rear wheel bearing on abs car
Old Mar 15, 2012 | 01:24 PM
JRTegman987's Avatar
Default non abs rear wheel bearing on abs car
The right rear wheel bearing on my 00 si its grinding beyond belief. Looking at the parts on autozone the price difference for the ABS vs non ABS bearings is double.
If I put the non ABS bearing on what symptoms am I looking at? If its just ABS doesn't work anymore (on thatvwheel or all wheels) I don't care at all. This is my first civic with ABS. But if its gonna make the ABS go nuts and pulse cuz it thinks its locked up because there is no reading then I would be up ***** creak.
Could I just remove a main fuse for ABS if that was the case?
ABS will eventually be removed from the car anyways but probably not for a while
Old Mar 15, 2012 | 01:41 PM
JDM_teh_WIN!!'s Avatar
Default Re: non abs rear wheel bearing on abs car
The 99-00 Civic Si did not have ABS.
Old Mar 15, 2012 | 01:51 PM
LOL never even checked just assumed it had it. Boy do i feel foolish
Old Mar 15, 2012 | 02:16 PM
Just an FYI, you can use ABS equipt parts on non-ABS cars but not the other way around.
Old Mar 15, 2012 | 02:44 PM
Thank you sir
Old Dec 2, 2023 | 04:16 AM
J-Ray frnkinciv's Avatar
Originally Posted by JRTegman987
Thank you sir
I have a 97 civic ex and put nonabs bearings in the original abs hubs all the way around and have had no problems
alexg103
Feb 23, 2010 11:16 AM
nico91civic
Nov 12, 2008 09:04 AM
skiptomylou
Apr 13, 2006 06:09 AM
psegs80
Dec 25, 2005 05:05 AM
2camsaam
Oct 3, 2003 07:29 AM
