n00b D16A1 swap...few questions.
Old Mar 15, 2012 | 04:54 AM
YungICY's Avatar
Icon2 n00b D16A1 swap...few questions.
n00b to honda and swapping. I just bought a project car (91 civic dx hatch) with a d16a1 (brown top) swapped in(or atleast from what i can tell based on what i was told and the research ive done). swap was almost finished. I need to get a intake manny w/ tb and i'm probably gonna need to get a wire harness. am i better off getting a d16a1 intake or a ZC? and if the ZC is there a specific one? and for the harness i might be able to salvage it but i need a diagram that shows basically what wires/plugs are needed to make the engine run.
Old Mar 15, 2012 | 05:10 AM
90civic-ZC's Avatar
Default Re: n00b D16A1 swap...few questions.
The d16a1 intake is basically the same as the ZC only difference is the d16a1 has a slight lean to it.....you can put either or on it.
Old Mar 15, 2012 | 05:40 AM
YungICY's Avatar
Thanks man. just incase i can't find a d16a1 manny is there a specific zc one i need?
Old Mar 15, 2012 | 08:18 AM
jlicrx's Avatar
just has to be DOHC ZC - ZC is much better than D16A1 - stay away from 86-87 D16A1 - use 88-89
for wiring, you need to use the DX engine harness and convert it from DPFI to MPFI
Old Mar 15, 2012 | 10:58 AM
YungICY's Avatar
thanks a million jlicrx. you just gave me the two answers i've been lookin night and day for, for the last week.
and just so i'm clear, i want an 88-89 zc intake and i'm gonna use the engine harness from my 91 dx and just convert it to mpfi?
Old Mar 15, 2012 | 12:50 PM
YungICY's Avatar
bump
Old Mar 15, 2012 | 12:52 PM
lazy14's Avatar
if its a dx it should be mpfi, if it has 4 injectors its good, unless thats only sedans
Old Mar 15, 2012 | 12:59 PM
YungICY's Avatar
yeah its got 4 injectors. thanks!
still a lil fuzzy on the intake though. i want an 88-89 or any 86-89 will work fine?
Old Mar 15, 2012 | 06:40 PM
Jockone's Avatar
Like jlicrx said stay away from 86 - 87 manifold and get an 88 - 89 manifold.
Use the wiring harness for your chassis and convert that harness to MPFI.
If you cant find an intake manifold hit me up I think I have one or two in the shed somewhere.
The Destroyer
11
Dec 30, 2005 02:22 PM
90b20b4
Jun 27, 2005 02:43 PM
justinau
Mar 26, 2004 06:52 AM
VelocityR
Nov 14, 2003 07:22 AM
Ronin Panda
Jul 12, 2003 09:12 PM
