h23/h22 vtec problem.. help :/
Old Oct 10, 2002 | 04:19 PM
f0de's Avatar
Default h23/h22 vtec problem.. help :/
i've got an EG9 with a h23a bottom end and a h22a crower head.. i had a h22a in the car previously but i destroyed the bottom end.. at that time i had a problem with the vtec engagement.. now that i took the motor out and put a new one in.. replace almost all of the sensors.. i have no check engine light now.. but the motor gets to about 7k.. and feels like it hits a nasty rev limiter.. kinda violent sounding.. not a normal cut off.. and it still lacks vtec.. i'm running a spoon h22a ecu.. which was tested in a stock prelude.. and it ripped.. but it just dosn't like my car.. any ideas would be greatly appreciated.. thx
Old Oct 10, 2002 | 04:25 PM
BoostedH23a1's Avatar
Default Re: h23/h22 vtec problem.. help :/ (f0de)
i wouldnt be supprized if it was a O2 sensor. u sure u have the VTEC wires hooked up. damn O2 if u cant figure it it its probably the O2. man those little bastards screw up everything. not saying thats it or anything..
Old Oct 10, 2002 | 05:12 PM
f0de's Avatar
Default Re: h23/h22 vtec problem.. help :/ (BoostedH23a1)
yah the o2 sensor was bad but i replaced it yesterday and it got rid of a few codes the ecu was throwing.. that didn't fix the vtec problem tho.. i'll check the wiring again tmrw.. thanks
Old Oct 10, 2002 | 05:58 PM
DCsquirm88's Avatar
Dam f0de what are you up to now? I think its about time you get a CL again .
Old Oct 10, 2002 | 08:18 PM
ichibanjap's Avatar
Can you give us a little insight on your h23 vtec install. Like any pics and what all you did to get it to work.
Old Oct 10, 2002 | 10:07 PM
Quiklude's Avatar
Default Re: h23/h22 vtec problem.. help :/ (ichibanjap)
you say you have a spoon variant chip, because the reason you are probably not throwing a code is these aftermarket chips remove alot/most of ecu codes.
my suggestion is to find a stock h22 ecu and plug it in and drive, and see if you get any codes...
Art
Old Oct 10, 2002 | 10:10 PM
f0de's Avatar
? you change a few gears on the block.. and put a head on it.. with h22a arp head studs..
i think the ecu could be screwing something up.. are there any other ecu's i can use that won't harm anything just to test it? i don't have any stock ecu's at the time.. but it showed the o2 code.. and a few others.. thx.. i guess i'll keep looking for a stock ecu..
dc.. find sumone to trade me shell for shell.. :] the cl would have been fast with this motor lol sCary fast
[Modified by f0de, 7:12 AM 10/11/2002]
Old Oct 11, 2002 | 06:29 AM
Jason kiDD's Avatar
Any pics of the car. Sounds nice.. And is the SIR a 2DR??
Old Oct 11, 2002 | 07:04 AM
fastludeh22's Avatar
Default Re: h23/h22 vtec problem.. help :/ (Jason kiDD)
the rev limiter you are hitting at ~6.5k is because the vtec not engageing. check w/someone who has an h22 in the same car and see if there was any wires you need to switch on the harness, i know there is a few in the accord, so maybe a few in yours. also check your oil level, if there is not enough oil pressure it wont engage.
Old Oct 13, 2002 | 03:27 PM
f0de's Avatar
Default Re: h23/h22 vtec problem.. help :/ (93ludevtec)
yah we found out the pinouts different on the h22a ecu.. and the impedence(sp) on the injectors is different too.. i'll keep you guys updated thanks a lot.. btw i got old pictures of the car on http://threefeetdeep.bounceme.net/ i'll take some up to date pics with a better camera in a few days..
Old Oct 13, 2002 | 03:29 PM
md23vtec's Avatar
i reccomened gettin some type or management system and going to the dyno with a stock h23 bottom end the compression is much lower and the fuel curve will not be close to the same as a stock vtec prelude. Try that out u migth be surprised
[Modified by md23vtec, 12:31 AM 10/14/2002]
Old Oct 13, 2002 | 05:21 PM
f0de's Avatar
Default Re: h23/h22 vtec problem.. help :/ (md23vtec)
well a spoon ecu is also meant for autoX.. so yes i'm aware its not the best choice.. but hey it was free.. so until i get a standalone.. this will have to work.. in conjunction with a safc
miguel_aka_timon
Nov 14, 2006 11:50 AM
hybridhatch07
Aug 26, 2006 08:42 AM
turbotime
Jun 18, 2003 03:19 PM
