Welding in the engine bay...
Old Mar 14, 2012 | 05:26 PM
ToTriggerHappy's Avatar
Default Welding in the engine bay...
what should i set my machine to? i believe its a 200amp miller mig with the gas. i just dont want to burn holes through the metal while im shaving it.
Old Mar 15, 2012 | 11:13 AM
teamjdm239's Avatar
Default Re: Welding in the engine bay...
depends on what gauge wire you are using, start from the lowest setting and work your way up. thats how i did mine
Old Mar 16, 2012 | 12:54 PM
ej1 rep's Avatar
Turn it way low, kind of a bitch to do but just do a million little spot welds around the perimeter of the hole towards the center.
Old Mar 19, 2012 | 01:10 PM
habmx's Avatar
Practice on a very thin piece of sheet metal with holes drilled in it!
Old Mar 19, 2012 | 04:28 PM
Golfball's Avatar
like stated above deff just crank the amps wayyyy down and see how she does and turn it up a little bit at a time till its good.
but most likely you will have to do a ton of spot welds like ej1 said so you dont build up to much heat in the metal and burn through.
Old Mar 19, 2012 | 05:52 PM
paulzy's Avatar
get a scrap piece of copper or aluminum for the holes that you can get to the backside of.
jasoncanseeoh
Welding / Fabrication
29
Aug 11, 2022 02:18 AM
EG-SIXV-TEC
22
Jan 19, 2010 06:02 PM
eg-spoon
Paint and Body
Dec 3, 2009 01:13 PM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
melovesboost
16
Feb 17, 2007 09:23 PM
