h22 parts blocks heads pistons cranks turbo all motor
--h22 heads port and polished $800
--h23 block no pistons no rods. Comes with crank girdle and main caps block was notched for h2b $300
-jdm h22 bare block only nothing besides the block itself $100
--bnib h22 oem style pistons std size comes with rings pins and locks $100
--oem rods $75
--4 h22 intake manifolds only $75
--h22 cams and gears few set of stock jdm and usdm $100
--jdm TypeS cams $300
--Hytech turbo manifold t4 divided with egt bungs welded on each runner $900
--h22 109 stroker setup never been used 109 welded crank, ross 90mm max dome pistons 16:1 compression and Cunningham rods $1000
--h22/h23 Arias 89mm bore 16.5:1 pistons new with pins, locks and rings $500
--h22 arias 87.5 9:1 pistons new with pins, locks, and rings
--96-2000 civic dx front power new stop cross drilled and slotted rotors with axxis brake pads $150
--p73-003 ecu $125
--hks gt 60mm wastegate in good condition with all parts $500
--oem rods $75
--p73-003 ecu $125
DxTrix
Jul 5, 2013 12:59 AM
