turbo integra over heating
i got a 1999 integra with the stock b18. when i drive over 120mph its starts to over heat. replaced the water pump, thermostat, and flushed the radiator. but it still over heats. it still has the stock radiator and fans and it still has ac would get a bigger radiator but would have to remove the ac the fans and trans already had to be trimmed to get the turbo to fit so i really dont have much room. could the ac thing that looks like a radiator be in the way or does it just need a bigger radiator
^^^yes but with a better cooling system it would work fine, your condensor does not help things, if u dont live anywhere super hot i would get rid of the ac and get a decent dual core. it is curious why youre doing 120mph when the limit is 55.
No need to remove a/c to get it to run cooler. I run a/c in my car and although it doesnt run cool (peaks at 210) thats on a 20 psi pull up to 150mph and i only have a half core radiator. if he is still running an oem sized dc radiator then it must be no good because it should run cooler than a half core does and should be able to sustain 120mph (even though its endangering lives)
1. Please tell me you replaced the Thermostat with an OEM one and did NOT use aftermarket junk?
2.To try and properly cool off your radiator, you will have to get creative and develop some type of air ducting that routes outside air directly toward the radiator. Since you still have a condenser its likely blocking the radiator from getting cooler air through it... get those fabrication tools out and think outside the box. Literally.
https://honda-tech.com/forums/showth...light=air+duct
^^ Check out this thread and go from there...
i was not driving non stop 120 just ******* on it for fun. i noticed that the fluid in the over flow smells like gas but the fluid in the radiator does not.and the radiator is stock
A good way to bring those temps down is to wrap your downpipe in that header wrap stuff. A lot of times with B and D series turbo cars the downpipe sits right next to the radiator and cooks the hell out of it.
Also, I agree with people who posted in this thread saying that ducting is your best bet.
A.R
Jan 5, 2012 06:24 PM
