08 Door Seals on Car (Not Door Itself)
So I snagged up an 08 EX-L last month with only 35k and im lovin it!! My question is, how can i seal the rubber on the car that the doors come in contact with to seal?? When you open a door this seal is on the vehicle that travels all around the opening. It comes away from the car a bit and i keep pushing it back up but drops again...any suggestions on glues to adhere it to the car?
Thanks
Thanks
Get a tube of rubber adhesive from your auto parts store, or Wal-Mart... run the stuff in the groove of the seal and stuff it back on... should do the trick...just don't use too much, it can be messy.
also , put a dab of SIL-GLYDE grease on ur finger and run it along the length of the door seal or the door side and cabin side it will help it not pull away when opening the door ( silicone spray can help as well )
94civiccpe
Jan 30, 2014 08:56 PM
braypunt
Apr 14, 2005 01:20 PM
