99 honda accord missfires under load when warm
Old Mar 14, 2012 | 06:25 AM
nesretep_316's Avatar
Default 99 honda accord missfires under load when warm
I have a 99 honda accord 2.3 v tech (f23a1) it misfires only when it is up to temp, under load and under 2000 rpm I decided to replace the motor because it's got a lot of oil blow by, has 306k miles on it and because of the misfire. all cyl were between 210 and 220psi compression test all sensors were tested and good including the obvious fuel injectors, the fuel pressure was also fine. When I cracked open the intake manifold I found a large amount of carbon build up in the egr tube could this have been the cause of all the problems?
Old Mar 17, 2012 | 06:14 AM
Lost Again's Avatar
Default Re: 99 honda accord missfires under load when warm
YES ! That is/was the problem. Clean it and I bet you have perfectly fine engine.
Old Mar 19, 2012 | 09:02 AM
I've got another motor I'm putting in. I think I'm going to be rebuilding the old motor and and turning it into a g23 I also found out that the balancer shaft belt had snapped after I took the timing cover off. I don't know how long it was like that but I thought if you took off the belt to the balancer shaft the oil wouldn't flow right and blow the motor. I did replace both belts in the new motor I'm putting in lol
Old Mar 26, 2012 | 04:06 AM
all installed I love it 10.5lb flywheel helped a lot I went with a stage 1 clutch to keep it drivable for the wifey
Old Mar 26, 2012 | 04:30 AM
dglassmyer's Avatar
That's gotta be the first engine ever that can be seen from outer space.
DesiraeA
Aug 10, 2018 11:04 PM
Dueceification
May 30, 2011 04:55 PM
davken1102
Sep 21, 2008 06:26 PM
DaMmniTz
Jun 15, 2005 10:53 AM
