Honda&Acura..B,D Series..Alot of Pics
Old Mar 14, 2012 | 02:36 AM
SlaminSohCivic's Avatar
Default Honda&Acura..B,D Series..Alot of Pics
Whats up Honda-Tech trying to sell some stuff...Paypal is Ready....Willling to take some trades if i need it...If Pictures Arnt on Thing forsale Let me know and if ur interested ill get u a Picture...thanks
1.
2.B-Series Hydro Tranny Shift Forks...Came Out of My Mint 98 Civic TYPE-R Tranny With Under 55k Miles...These go for $85.00 Each at Honda Dealer...$115.00 Shipped for All 3
3.B18C1 USDM Crank Shaft 65k Miles...All Jernouls Are Perfect...And Didnt Spin no Bearing...Cracked a Sleeve...So im parting it out...$145.00 Shipped
Thats Cheap Ive seen Atleast 3 on Here for $200 +Shipped
4.(5) B16B PCT Pistons...1 Has Detonation...But Ill Send you All 7 Of them and u can get atleast 4 to work perfect....$65.00 Shipped for 7 Pistons Only 5 Pictured
5.AEM Silver Cold Air Intake Tube...Has AEM C.A.R.B Sticker/AEM Black Silcone Coupler...Has Mount to were it mounts to ur Frame Like Oem...these are over $200+New....Asking $60.00+Shipping
6.B-Series And will Work on D-SERIES...IVAC Sensor I bought this Brand New from Honda Last Spring...Only Has under 4,000 Miles on it...I Paid $118.00 New ...Asking $50.00 Shipped
7.95 Civic CX/VX D15B8 8 Valve Non-Vtec Head/Valve Cover/Complete Intake Manifold/OBD1 Dizzy...$200.00 Shipped For everything Listed...Great Set Up For Gas Mileage 45+ Miles
You can See Head and Manifold in this Picture but not the Best ill get better pics if Interested
8.94&up Integra OEM Clock $12.50 Shipped
9.B18C1 oem Knock sensor was off Usdm...85k miles...$45.00 Shipped
10.DOHC ZC Zxle's &Half Shaft...Ends Just Need clamped back on...No ripped Boots.these are hard to find since there for JDM...$100.00 Shipped
11.92-95 Civic Clutch Pedal Only for Hydro...$35.00 Shipped....I thinking its a EK Clutch line down to tranny..$35.00 shipped
12.99-00 Civic SI B16A2 Dohc Vtec Cams...Mint Condition...Under 100k Miles...$60.00 Shipped
13.96-98 Driver Side Head Light..Lil fade can be fixed...OFFER
14.95 Civic Si Hatch P/S Steering Rack...No Inner Tie Rods...$65.00+Shipping
15.Accord External Coil..$5.00+Shipping
16.90-91 Integra LS 5 Speed Guage Cluster..Mint conditon..Will check Miles&Get pics if interested dunno off hand...$65.00 Shipped
17.Honda/Acura VTEC Plugs..$20.00 Shipped
18.1994 Acura Integra LS 14" hUB Caps...Mint...2 are painted gloss black other 2 Silver...$30.00+Shipping
19.97 Civic DX Passenger Side Hub...Perfect Wheel Bearing...$50.00 +Shipping
Also Stock Struts and Springs Forsale With Forks...Offer
20.B18A1 OBD0 5 Speed 90-91 B18A1 Ecu...These are hard to come by in some places $75.00 Shipped
22.88-91 Civic SOHC Rear Mount Bracket $22.00 Shipped
23.92-95 Civic Grey Dash Cover..good condition...$15.00+Shipping
24.Prelude Passenger side tail light needs a bulb or 2..Good shape..just a random landing around...$15.00+Shipping
25.B-SERIES Hydro Brand New Pressure Plate...Paid $169.00 For Clutch Kit at Autozone and Only Used Clutch Disc...$70.00 Shipped
26.D15B7 Steel Mount&Bracket $30.00 Shipped /D16Z6 Aluminum Mount/Bracket...Good Mount Rubber...$45.00 Shipped
27.92-95 Civic eX Power Steeringg Set up...P/S Pump,Main Line From Rack to pump 2 10mm Bolts....Front p/s cOOLER/Resovoler/Bracket/2 Lines from Rack to P/S Can....$80.00 Shipped
28.92-95 Cead Lightsivic SI Hatch Power Driver Black Door Panal Great shape...$45.00 Picked up
~99-00 Civic Head Lights...Eye Lids Painted on..One Broken Tabb on Driver Side Tab...$70.00 Shipped There Big So Got to Be shipped
~92-95 Civic CX 5 Speed Hatch...No Tach...$42.00 Shipped
29.B-SERIES HYDRO Passenger Side Inner Hub I think 36mm..Was Brand new and my buddy dunno how to pop Lower Ball Joints and he pulls them apart stupid buyin new axles every swap...But i grabed this end ...$20.00 shipped
30.92-95 Civic Climate Control Unit...good shape...$45.00 shipped
31.D16Y8 OBD2 5 Speec ecu p2p..$65.00 shipped
32.90-91 CRX HF 5 Speed Gauge Cluster No Clear Plastic...Rare..$60.00 Shipped
33.92-95 Civic EX Sedan ABS ECU IN Trunk/with cover...$60.00 shipped
34.91 Integra 15/16 Brake Booster...$65.00 Shipped
35.Black Leather Rear Seats...Out of Something like RSX or Something...They have the Split top Seats...Will Lay in a EG Hatch Perfect..But the Bottom Brakets of the top Seats dont go in they dont have the hole on inside and post on out side...Just 2 10mm bolt holes...but can forsure be fixed perfectly...$125.00 Picked up
36.92-95 Civic Cruise Control Units i have 5 ...$25.00 shipped Each
37.92-00 Civic Main Relays...$25.00 Shipped Each
38.90-91 Integra OEM Front Headlights...Complete...$130.00 Shipped for Set
39.D16Y7 OBD2 Manuel P2E ECU $50.00 Shipped
D16Y7 OBD2 AUTO P2E ECU...$35.00 SHIPPED
40. 96 Civic TAN Under Dash/Fuse Box Cover $10.00+Shipping
~93 Civic DelSol Black Under Dash/Fuse Box Cover...$15.00+Shipping
~95 Integra Black Under Dash/FuseBox Cover $15.00+Shipping
~91 Civic Black Under Dash/FuseBox Cover $12.00+Shipping (Im 97% Sure its EF Not EG If im Wrong let me kno
41.D16Z6 SOHC Manuel Rear Tranny Bracket...$45.00 Shipped Each
42.92&up Civic&Integra Main Relays...All Working Condition..Came out of Running Parts Cars...$25.00 Shipped Each
~OBD1 Civic/Integra ECU Plugs/Pigtails $25.00 Shipped for All (3)
~D16Z6 OBD1 Vtec SoleNoid...Worked When Came Off Head ...$35.00 Shippped
~OEM Honda Oil Caps $10.00 sHIPPED Each /OEM Honda Gas Caps $10.00 Shipped
~OBD2 Distributor Plug im Sure $10.00 Shipped
~OBD1 ALTINATOR Plug/Pigtail $8.00 Shipped
~96 Civic Tan Trunk Puller And Gas Cap Opener Covers $10.00 Shipped
43.92-95 Civic Climate Control Unit...A/C Button isnt there Because it Was CX And i used Block Off..$40.00 Shipped
44.(8) Used B18A/B Rods&Pistons...Not In Bad Shape...Blocks just spun bearings And kept pistons&Rods...I will Sell Each Set of Rods&Pistons for $60.00 Shipped or Take all 8 for $100.00 Shipped And all Rods are Perfect and all pistons are good
45.92-00 Civic Whiper Motor Set up/with Rods....$60.00 Shipped
46.92-95 Civic EX Auto Cruise Control Computer for Cruise Control $40.00 Shipped
47.94 Integra LS Coupe....3rd Brake Light...Perfect Working Condition..Just Dusty in Picture From Basement...$30.00 Shipped
48.92-95 Civic OEM HeadLight Glass..Both Sides...Driver/Passenger...$30.00 Shipped Each or Both $55.00 Shipped
49.90-93 Accord Driver Side Tail Light...Fair Condition...$8.00+Shipping
50.92-95 Civic EX/SI Power Mirrors Driver&Passenger Side...Both in Great Condition...$70.00 Shipped for Set
51.96 Civic TAN Steering Colum Cover..Mint Condition...No cracks..Etc...$20.00 Shipped
52.(2)88-91 Civic Black Colum Covers $15.00 Shipped Each
~92-95 Civic SRS Steering Stem Cover...Great Shape..$12.00 Shipped
~92&up Civic Fuel Pump Hanger $17.50 Shipped
53.88-00 Civic Hood Lach Puller...$12.00 Shipped
~Heater Core Switch Valve For Heat Goes in
54. IF INTERESTED IN ANYTHING IN PICTURES BELOW PM OR
wILL ADD More
Looking for Front Mount Intercooler good for 400 whp
B18C EAGLE H BEAMS
Old Mar 14, 2012 | 02:51 AM
1sikhatch's Avatar
Default Re: Honda&Acura..B,D Series..Alot of Pics
good deal on that gear set
Old Mar 15, 2012 | 11:00 AM
bump..thanks sikhatch
Old Mar 15, 2012 | 01:53 PM
jdmem205's Avatar
I'm interested in the iacv and main relays what shape are the relays in any pics?
Old Mar 15, 2012 | 03:06 PM
94CoupeNY's Avatar
im looking for a set of 8 good gsr rocker arms if you or anyone has them, i would start a wtb but to new still.
Old Mar 15, 2012 | 08:35 PM
No Rocker Arms 94 Coupe....I have main relays Perfect shape
Old Mar 20, 2012 | 09:45 PM
bump
Old Mar 21, 2012 | 05:35 PM
boostfedblackek's Avatar
PM'd, I need the solenoid and the plugs
Old Mar 21, 2012 | 06:51 PM
dc5itracer's Avatar
I got a intercooler for you text me 9084252005
Old Mar 25, 2012 | 07:00 PM
SyLee Duk's Avatar
PM Sent
Old Mar 28, 2012 | 11:12 PM
BUMP...BUY THIS STUFF GUYS
ITEMS SOLD&SHIPPED
B18C1 OBD1 Knock Sensoe
D16Z6 Vtec Solenoid /OBD1 Vtec Plugs
B16 IVAC Sensor
SPEC Stage 3 Pressure Plate
Old Mar 30, 2012 | 06:49 AM
Hatchb96's Avatar
bump
Old Apr 2, 2012 | 11:38 AM
bump
Old Apr 2, 2012 | 12:18 PM
ryguy2588's Avatar
PM'd
Nick M
Jun 11, 2006 08:35 PM
BioXide02
Oct 15, 2005 08:33 PM
H2nr
Nov 29, 2004 07:00 PM
voltageGSR
Apr 2, 2004 08:00 PM
94civicexlsvtec
Jun 23, 2003 07:28 AM
