jdm b16a
ok heres my situation. i have a jdm b16a(2nd GEN) in my 2000 civic dx hatchback, anyways ive spent countless hours reading retaining powersteering faq for ek. i have the powersteering line still hooked up and what now , i have a upper p30 bracket for the PS pump( no idea if its the DEL SOL VTEC) and it wont line up, the previous car that this motor was in was 1996-1998 civic SI (not original motor for this car,owner did a swap. then i bought off him) and it did work in that car why not mine? was the upper p30 mount different for 1999-2000 PS pumps?
Well, there was no 96-98 SI unless you live in Canada, so that might be part of your problem. If you are Canadian, then the 96-98 SI is what the rest of the world calls the EX.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ek-b16-swap-how-i-kept-power-steering-easy-2916290/
http://www.civicforumz.com/showthread.php?t=162192
These threads seems relevant to your interests, although I'm not personally 100% sure. If that doesn't help, someone else might be able to help you out a little more.
weird tho, my brothers car is a 1999 civic si, originally came with a d16y8, put a 95 gsr and still has powersteering, he didnt have to change the pump or any lines to b series from d series. he just got the brackets and everything worked for him not for me , anyone know what brackets i would have to use? also, i have already read the two posts above, didnt help me. pease someone must know...
cafrog
May 19, 2009 06:32 AM
Moses154
Oct 7, 2007 09:55 AM
WakeSpliter
Mar 3, 2004 02:19 AM
VWkila
30
Jun 13, 2003 12:35 PM
