integra trunk release motor is not working
Old Mar 13, 2012 | 10:41 PM
raverx3m's Avatar
Default integra trunk release motor is not working
i took apart the trunk release motor assembly thinking its the lil clutch thing that was a common problem but it is intact and so is everything else.
tested ground and 12v both are good.
tested the motor from a 12v battery and it doesnt turn very much.
the motor turns untill theres resistance in the clutch and stops.
if i pull the gears out it spins but very easy to stop...
is there a replacement motor for that trunk release assembly i can buy?
Old Mar 14, 2012 | 06:17 AM
fcm's Avatar
fcm
Old Fart
Default Re: integra trunk release motor is not working
What year is the Teg, I have the compete system that I pulled out of a 2000 Integra thinking I could install it on my 94, but turned out it was going to be too much of a PITA to do, you can buy the actuator, $100+ from the dealer, much less at a PicknPull. 94
ChillinInTheDA
Feb 1, 2011 10:46 AM
adhawk76
Dec 11, 2009 08:28 PM
