Brake fluid dripping down inside of firewall.
Old Mar 13, 2012 | 08:05 PM
Charismatica's Avatar
Default Brake fluid dripping down inside of firewall.
So my clutch master cylinder needs to be replaced. Theres been fluid running down the inside of the firewall and now theres probably big spot of paint the size of a grapefruit that has started to peel off and rust a little bit right below the clutch pedal and a little underneath the carpet. Car is a 2000 hatch. What are your recommendations for this repair, as far as what to use to clean up the fluid, and is a body shop necessary? thank you
Old Mar 14, 2012 | 04:49 AM
tepid1's Avatar
Default Re: Brake fluid dripping down inside of firewall.
Remove the rust, hit it with a degreaser a few times, then prime/seal. It's inside the car so it doesn't have to be too fancy.
Old Mar 15, 2012 | 12:14 PM
what is the ideal way to remove the rust?
Old Mar 15, 2012 | 12:16 PM
joeshmo's Avatar
I personally like wire brush attachment for my drill, but heavy grit sandpaper works too.
ZacEXbrown
Apr 5, 2018 03:55 PM
97tegGS
Feb 24, 2017 01:24 PM
ccoake1
Honda Civic (2006 - 2015)
Jan 14, 2017 09:19 AM
erikiksaz1
Suspension & Brakes
Jul 31, 2009 12:36 AM
prjctsilverknighty2k
Transmission & Drivetrain
Jun 8, 2009 10:47 AM
