D16ZC Wont pass emissions.
Old Mar 13, 2012 | 03:47 PM
boostedef123's Avatar
Default D16ZC Wont pass emissions.
Ok so I got this hatch around 2 weeks ago. Ran it through emissions and it failed. Badly. Read 389 HC and 2.97CO Limits aare 220 and 1.20.
This is when I found out the complete evap canister was missing from the motor and was ran completely incorrect. Went to the junkyard and found one and fixed it.
Reran it today with a bottle of alcohol in it and it read 308 Hc and 2.34 CO
My main question is I dont have a cat on it at all but somehow it passed the visual inspection. If I install a cat will it clean the exhaust enough to pass or is something motor wise running incorrectly on here. I have not messed with the ignition timing at all so I am sure I can run it back if that would help. Just need ideas Id like to get it to pass this next run.
Old Mar 13, 2012 | 06:47 PM
KINGVEM^^ED6's Avatar
Default Re: D16ZC Wont pass emissions.
You need a cat to pass
Old Mar 13, 2012 | 08:24 PM
MONSTERZC's Avatar
what state are you in. The test they performed is a two speed idle. since you dont have any nox numbers. I need some more information. What mods have u done to the car. what ecu do you have. is your coolant temp sensor in good working order, when is the last time you tuned up car. is your o2's hooked up, when is the last time you had an oil change.
Old Mar 14, 2012 | 02:19 AM
Im in TN. The o2 is hooked up but im not sure as to how old it is. Its a stock zc. Doesnt even have 1000 miles on the rebuild. And im asuming that its working correctly it read the temp and everything in cabin fine.
Old Mar 14, 2012 | 02:52 AM
Dioxine's Avatar
A cat would defenitly help. But thats really all i know. I live in Kansas no emissions, drive a turbo lsvtec with a 4 inch exhaust dump right out the side of my bumper lolz.
Old Mar 14, 2012 | 06:05 PM
HardSaltydogg's Avatar
I live in Cali, toughest state to pass
I did pass because it isnt a state legal swap, but got tested any way.
Run a PM6 (Stock SI) ECU
Catylic
Good Gas
Igntion Timing a little lower then 18 deg.
Good Luck
Old Mar 14, 2012 | 08:08 PM
Shaunathan's Avatar
lol why would you post here if you dont even have a cat on your car?
Old Mar 15, 2012 | 01:12 PM
JDpower's Avatar
I got my jdm DOHC ZC to pass smog in Cali too, they tested mine like a d15b2 since thats what the BAR sticker said. It passed that test with a pm6 too (failed with PG7 and 91 gas) and 87 gas. Tune up, cat , new O2 and warmed up good.
Old Mar 15, 2012 | 03:43 PM
Because Im trying to avoid putting one on there. Its money I dont have to spend if I can. Im not failing due to no cat anyways.
Old Mar 15, 2012 | 04:11 PM
4drEF's Avatar
Keyboard Humorist
A cat does a lot more than sit on your car to look visually emissions compliant.
Putting one on is going to change your emission readings.
Old Mar 15, 2012 | 04:16 PM
freydaddy's Avatar
retard the **** out of your timing until you pass.
Old Mar 15, 2012 | 11:23 PM
Ottawabook's Avatar
lol
Old Mar 16, 2012 | 07:02 PM
MONSTERZC's Avatar
Is the motor stock. i would change the oil , check the plugs to make sure they are nice and clean. if they are dirty i would change them. when i asked about the coolant temp sensors you have two of them one for the gauge cluster and one for the ecu to adjust the air fuel ratios. if the sensor is bad it will make the ecu think the car is always cold even though the car is warm.
Old Mar 19, 2012 | 08:35 AM
video_voide's Avatar
....you have two of them (coolant temp sensors) one for the gauge cluster and one for the ecu to adjust the air fuel ratios. if the sensor is bad it will make the ecu think the car is always cold even though the car is warm.
Hey, which of the two coolant temp sensors aids in adjusting the AFR's?
Old Mar 19, 2012 | 05:48 PM
Put on a cat still failed. Looked into this issue further and found my Exhaust cam shaft was off by 1 tooth. Reset crank to TDC and reset my cams. Holy **** this motor came alive. Gonna rerun tomarrow and see what happens
Old Mar 19, 2012 | 06:09 PM
MONSTERZC's Avatar
You should pass now. the converter wasn't the issue here because they aren't testing for nox. Good Luck. The new numbers should be in the 1.10hc and .068co range.
Old Mar 19, 2012 | 06:11 PM
Should I still try retarding my iginition timing? Im kindy iffy if that was actualy the issue all together.
Old Mar 20, 2012 | 11:43 AM
MONSTERZC's Avatar
If it was me no. just move the dizzy so the bolt hole is in the middle postion. Rev the car for 60seconds at 2000 t0 2800 rpms. Then let it idle for 60 seconds if it doesn't smell rich you should pass.
Old Mar 20, 2012 | 04:29 PM
Ran it through today passed with flying colors 70 HO and no co lol
Old Mar 20, 2012 | 05:12 PM
EFnCRX's Avatar
hell yeah! time for some
Old Mar 21, 2012 | 07:12 AM
MONSTERZC's Avatar
Good job.
Ritchie
24
Jul 1, 2007 07:30 PM
boots420
37
May 18, 2007 03:35 PM
HondaHeddie
Dec 21, 2006 08:17 AM
SiRII_Izzy
21
Aug 24, 2004 07:06 PM
ProudtobeANoob
Mar 7, 2003 02:53 PM
