Oil Pressure Issue
I did some searching, but I couldn't find anything similar to my issue. So here is my issue, I have a LS/VTEC (B18B1 bottom with B16A head) using the Golden Eagle VTEC conversion kit to supply oil to the head. I have good oil pressure on load about 80 psi, but right at VTEC crossover 5300 it drops about 20 psi causing VTEC to not engage then all of a sudden it jumps back to 80. I have replaced the o-ring on the "black box" since it was bad and even put a new oil pump, but the issue still exists. Any other suggestions would be greatly appreciated.
I just mentioned the GE kit so you guys would know how the oil was getting to the head, but I'm not ruling it out. Never heard any issues with the kit though.
Yes the o-ring is there.
PH3593A
11
Jul 19, 2023 02:36 AM
tobster
Mar 13, 2011 12:32 PM
