zc hood/ sir hood
Old Oct 10, 2002 | 03:26 PM
incubus's Avatar
Default zc hood/ sir hood
hey guys I did a search to find out if the ZC or SIR hood will fit my car(91 crx)and turned up nothing. I am pretty sure that they won't, but I always see people on e-bay selling them saying that no midification is needed and that it is a bolt on affair. r they just stupid or lying? as far as I know the headlights are thinner on the jdm's and the front bumper cover is shaped different causing these hoods to not work on usdm's.
My problem is that my b16 sits too high, I have the bump stops adjusted and the latch spring adjusted to keep the hood from hitting the valve cover, I did read that most people don't have problems with this though. I don't know what motor mounts i have but I know they are not HASport (mine rubber bushings).
N E answers or suggestions?
Old Oct 10, 2002 | 03:29 PM
Jaker's Avatar
Default Re: zc hood/ sir hood (incubus)
ZC hood exact same fitment as USDM hood.
SiR hood needs JDM headlights, rad support and bumper to fit properly.
Old Oct 10, 2002 | 03:32 PM
incubus's Avatar
Default Re: zc hood/ sir hood (Jaker)
SO the jdm si's and jdm sir's had totally different headlights radiator supports and bumpers?
that seems weird.
Old Oct 10, 2002 | 03:53 PM
USDM 4G VTEC's Avatar
yup
remember one has a B16A and the other one a ZC....
Old Oct 10, 2002 | 03:56 PM
NikoZai's Avatar
Do they have Si's in Japan. I thought they only had SiR's and that other luxury model we get the power everything off of. KA model or something..?
"SiR hood needs JDM headlights, rad support and bumper to fit properly"
Is the radiator support weld on or bolt on. and is there a bodykit maker that makes a Mugen style front end modified to fit with the original JDM hood?
Old Oct 10, 2002 | 04:52 PM
bryant's Avatar
Default Re: zc hood/ sir hood (NikoZai)
Rad support is bolt on. This is an SiR 'Style' hood. That is almost the same as the real thing, just the Style one fits the USDM front end. What are you looking to do with the hood? you just want it for looks? Yes they had Si's in Japan.
Old Oct 10, 2002 | 04:54 PM
marty's Avatar
Default Re: zc hood/ sir hood (CR-X)
They had " HF " too.
Old Nov 30, 2002 | 01:05 AM
evilxkid's Avatar
i have a sir hood i could part with if you want to make an offer
Old Nov 30, 2002 | 02:20 AM
3gLuder's Avatar
Default Re: zc hood/ sir hood (evilxkid)
My ZC hood looks and fits great. Bought it on Ebay. I am still SOHC though. Love the underhood labels.
Old Dec 30, 2002 | 02:10 AM
incubus's Avatar
nahh, don't want a SIR hood.
would consider a ZC, but I might just go with a CF SIR(inverted) hood.
Old Dec 30, 2002 | 04:29 AM
REX VT's Avatar
This is what you get when you use non -SiR parts onto a SiR.. it just doesn't fit.. in this case it looks like crapp..
Old Dec 30, 2002 | 10:16 AM
PaImportTuner's Avatar
Default Re: zc hood/ sir hood (REX VT)
hmm call me an ASH-HOLE-LAY but I think that bumper looks good EVEN with the minimal non-aligned bumper to hood. seriously.. anyone have a SiR Bumper??? **** i'll do it. GOT ANY OTHER PICS FROM DIFFERENT ANGLES??
[Modified by PaImportTuner, 7:17 PM 12/30/2002]
Old Dec 30, 2002 | 10:21 AM
S13 slide's Avatar
Default Re: zc hood/ sir hood (PaImportTuner)
Old Dec 30, 2002 | 11:28 AM
E-AT_me's Avatar
Default Re: zc hood/ sir hood (S13 slide)
the SiR has a B16a
the Si in japan has the ZC motor
then there is the 1.5x which is carbed..
all civics/crx's came with the "SiR" front end from 1990-1991.
only Si's came with a ZC hood from 88-89.
ZC hood bolts directly on without modification.
Old Dec 30, 2002 | 11:59 AM
gray89si's Avatar
Anyone know if fiber images offers a version of the CF ZC hood?
Old Dec 30, 2002 | 01:47 PM
Default Re: zc hood/ sir hood (gray89si)
I know VIS has Carbon Fiber ZC and SiR hoods.
Old Dec 30, 2002 | 02:25 PM
Denny317's Avatar
Just wanted to point out that the VIS CF SiR hood only fits the JDM front end, and not the USDM front end. If you want one that fits the USDM front end, the only one out there right now is Fiber Images...which is still too pricey for me
Old Jan 9, 2003 | 06:38 PM
incubus's Avatar
Default Re: zc hood/ sir hood (Denny317)
how much does the fiber images cost? anyone know?
Old Jan 9, 2003 | 06:52 PM
Jsmx5's Avatar
Does anyone know if the VIS hood requires the use of hood pins or will it work with the stock latch?
Old Jan 9, 2003 | 07:14 PM
chief_rucka's Avatar
Default Re: zc hood/ sir hood (Jsmx5)
i still have to put my ZC CF hood on!! i thought it came with a latch oh well have to keep rotating back and forth. imma use hood pins cuz im scared, and for safety reasons of course. but i dont want to ruin a CF hood. who wants to?
Dark_Teg
20
Apr 16, 2009 10:59 AM
incognito E46
May 12, 2007 01:16 PM
the niz jiz
Mar 7, 2005 05:51 PM
ViperRedCRX
Mar 27, 2003 04:37 AM
CRexcellence
10
Nov 26, 2002 07:59 PM
