CRX 91 charcoal canister remove
Old Mar 13, 2012 | 09:47 AM
Andrew.DC07's Avatar
Default CRX 91 charcoal canister remove
Hi, I wanted to ask you to remove all the clean style CRX 88-91charcoal canister, hoses, tubes and two way valve? Please advice. Andrew from the Czech Republic. thank you
[IMG][/IMG]
Old Mar 13, 2012 | 03:39 PM
EFnCRX's Avatar
Default Re: CRX 91 charcoal canister remove
Easy as pie but make sure you dont have to pass and smog or emission tests in your area! Just loop the hoses and pull out the canister.
Old Mar 14, 2012 | 05:28 AM
emission test can do, just remove it now. Thanks
Old Mar 15, 2012 | 05:22 AM
and the two way valve on the tank removed too?
Old Mar 15, 2012 | 12:42 PM
Randysi's Avatar
Do you cap off the tank where the red line goes into it?
Old Mar 19, 2012 | 11:11 AM
Everything is red only goes into the tank, but no cap
Old Mar 19, 2012 | 11:34 AM
KINGVEM^^ED6's Avatar
Just cap throttle body
And run red hose coming off firewall down towards the.ground
Old Jan 18, 2014 | 09:56 AM
acmoc's Avatar
There is a hose coming from the bottom, what do I do with this one?
Old Jan 18, 2015 | 07:47 AM
gabrielsousa's Avatar
any knows if i can remove the purge cut-off solenoid valve and connect the canister directly on intake ?
honda_fan06
Mar 27, 2011 10:16 PM
2001integra
Jun 11, 2008 08:52 PM
Chase
22
Mar 21, 2005 02:59 PM
GSRCRXsi
14
Sep 12, 2004 08:34 AM
