Mig regulator freezing
Old Mar 13, 2012 | 08:17 AM
bcumbie's Avatar
Default Mig regulator freezing
Last night while welding up some exhaust pipe I noticed my regulator froze over. Well it had frost on it. I'm in east Texas and the weather was not cold or really even cool last night. (75• F or so) the gas coverage went to crap when I noticed. Setup is 75/25 argon co2 mix with a hobart 140. I would say I was welding for about 40-45 mins. Another point I should make is the gas cut off solenoid is sticking on my welder causing the gas to keep flowing after trigger is released. I plan on fixing that ASAP. Could the continuous gas flow cause this?
Old Mar 13, 2012 | 08:52 AM
bcumbie's Avatar
Default Re: Mig regulator freezing
Got in touch with my LWS and they are ordering my contractor switch. They said this is what is sticking causing the gas to flow continuously.
Old Mar 19, 2012 | 12:40 AM
SleeperGSR-T's Avatar
Hey make sure your shielding gas is dissolved form. I forget what its called but I had the same problem. Changed my bottle and the freezing stopped.
You may have the right gas but in the wrong form. It works for a bit then frozen regulator and no more coverage
Old Mar 19, 2012 | 11:28 AM
HickamHatch's Avatar
This can also happen if your any of your fittings aren't tight on the regulator
luisrblue
Mar 24, 2009 08:56 PM
GI8U2racing
17
Mar 26, 2007 01:27 PM
mahatma
Nov 27, 2006 08:14 AM
ggangtong81
Oct 12, 2003 06:23 PM
