A/C Blower Issues - 06 MDX
A/C on the dashboard stopped blowing a couple days ago. I removed the Transistor assembly and replaced the resistor, after noticing that it did not have continuity. It was a cheap easy fix. Now A/C only blows on high. Plug on harness is not burned or melted. Should I replace the transistor assembly now? I also changed out the pollen filter.
Is the transistor assembly function as the resistor pack or control assembly for the A/C?
94DCTeg
Jan 20, 2010 04:19 PM
