b18b1 turbo question.
I had a quick question about a b18b1 turbo build im doing, im going to be using dsm 450 injectors and im only going to use 7psi on the turbo, what other fuel mods should i do or is the 450 injectors good enough since its so low boost?
7 psi doesn't mean anything to us, what turbo?
You should be fine. Id get a walbro 255 just to be safe and upgrade your stock one.
You sure those don't require a resistor box?
And will you be getting it tuned?
