Shifter Vibration
Old Mar 12, 2012 | 12:10 PM
Ryan96GSR's Avatar
Default Shifter Vibration
I did a quick search, but most of what I read was dealing with aftermarket shifters etc.
My car is 100% stock, I notice around 4000-4500rpm the shifter vibrates while driving under load and in neutral if I bring up the revs. Also not sure if this matters but the shifter moves around while it's in gear(left and right).
Just wondering where I should start looking.
Old Mar 12, 2012 | 12:32 PM
GagnarTheUnruly's Avatar
Default Re: Shifter Vibration
It's possible you need new linkage bushings. They are cheap and easy to replace.
Old Mar 12, 2012 | 01:08 PM
grjr's Avatar
Shifter movement can be caused by worn engine mounts. Could be the rear engine mount.
Old Mar 12, 2012 | 02:15 PM
TheRealTegger's Avatar
This ^^^.
Also the bolt/nut might just be loose. If that's the case, the problem may be solved simply by re-tightening the nut.
When replacing the bushings, the tough part is getting the old plastic bushings out of the hole in the shifter. There's precious little room to work, and they're often stuck in there really good. Needle files and dentist's picks help quite a lot. And you MUST drop that heat-shield!
Old Mar 12, 2012 | 02:26 PM
doood's Avatar
been there done that
years ago when i replaced those bushings on my old civic the bushing was busted so bad it fell out as soon as i disconnected it from the shifter. not much room to work and get leverage under the car so i took the rod out completely.
Dm914
Apr 20, 2017 06:55 AM
MiamiEgGSr
Nov 4, 2007 04:37 PM
vwtohonda
Aug 7, 2006 08:55 AM
eluder33
Nov 20, 2004 03:05 PM
slash00R
Nov 1, 2004 07:23 PM
