Running rich better than lean?(more info.)
okay guys so the situation is my car is running very lean atm after putting in headers(we opened it up,inside was white due to running very lean). Is their a temporary solution to just add an aftermarket pressure regulator and add more fuel(to run a bit more rich) for now until i can afford to do obd2a-obd1 conversion, obd1 ecu, chipped ecu w/ hondata s100, and labor for a air/fuel tune...
opened what up? what was white? what engine and what's the setup? doubtful a header by itself will make the engine run so lean you cause damage.
motor is 98 b18c1.
running all stock except intake, header(and high flow cat),and exhaust;I haven't finished my exhaust setup though.
a better way of determining lean or rich without an actual wideband is pulling the plugs. white tips = lean black = rich
but you havent really made enough changes to drastically affect the a/f ratio
but why would the internal of the engine look white(the area where you can see inside after removing headers).
take the spark plug out. u can use a deep 5/8 socket with a long extension with the rubber tip that grabs the plug or unscrew it with a regular deep socket 5/8 and pull the loose spark plug with needle nose pliers. its very simple.
Back in the day before wideband O2 sensors were easily available, we used to use glass spark plugs to see the combustion and determine rich / lean conditions by color.
You kids these days are so spoiled, and yet, still can't figure out how to simply google how to read plugs...
that's why i've never done spark plugs..
so can someone tell me why the inside of the engine(where you pull the headers you can see partially the internal of the engine or head) is white? i just want that answered so i can sleep at night aha..hopefully nothing bad.
