Motor Mounts EP3
Wanting to know how much it would cost for professional installation of new motor mounts, and if it would be cheaper to have only the bushings replaced? if thats even possible. looks like the rubber in the stock mounts is melted....
You can buy motor mount inserts that fill in the gaps of the OEM mount, but you can't replace just the bushings. That's your cheapest option.
I have no idea how much installation would be, call around and ask.
to the op: i bought my oem mount online (since its cheaper plus no sales tax sometimes) and then had my mechanic install it. i put in esmm for the front and rear (4 hr tops diy btw) and then had him put in the passenger side motor mount ($20 dollar tip and 15 mins with power tools).
as far as bushings are concerned, i do not have personal experience. i would that it could be quite pricey if you bought a master bushing set by Energy Suspension because that is quite a bit of pressing and replacing to do.
spcrxracer
Dec 29, 2013 08:10 AM
