1990 Accord LX Sedan NO Tail Lights
Headlights work, Front parking lights work, brake lights work........
Tailights do NOT work. Other than fuse, stalk swtich to check, any other area ? Where is the "multiplexer" I read on another post ?
When you said brake lights work, do you just mean the third higher up light or all 5 of the brake lights work? The rear bulbs are dual filaments and I would think if the brake lights work the tail should also. I would think the contact on the bulbs could be rusted, try cleaning them.
All brakes lights including the 3rd brake light are working (inlcudiung dash lights). Brake circuit is separate. I have to find the common ground (in trunk area ?) as this is shared by all rear tail / license. Front parking lights on a separate ground and they work (confirms combo swtich OK).
They seen to come on intermittently.
rgabriel
May 10, 2011 07:46 AM
1JDMDOMINICAN
Oct 28, 2005 06:34 AM
