Accelleration Problem...
1990 Civic 1.5
Ok so I replaced the spark plugs, wires, and dist cap, and the car ran great. I adjusted the valves once when the car wasn't cold, then I realized I made a mistake and adjusted them again the next morning when the car was cold. The car ran good, but then I noticed a problem.
The car would (and stil does) run great when you first start it up and its cold, I can cruise around at 1k rpm if I want to. As soon as it warms up, the car barely be driveable under 3k rpm. It acts like it's misfiring or something. It will buck pretty bad. I cleaned out the intake and stuff with some carb cleaner, nothing. Changed the o2 sensor, nothing.
I tried to find a second o2 sensor on my car... I can't find it anywhere. What could be causing this problem? I checked all the spark plug wires and made sure they were secure, they are. Could it be the dizzy cap??? Any help would be great thanks!
Original motor. Approx 235k on the clock. Before I changed the o2 sensor it would throw a code on the freeway when it was kinda cold... never could find out what it was because each time I turned the car off it would go away and not come back. Since I changed the sensor I haven't seen a code once
Pull up the carpet on the passenger footwell, take a look at the ECU. Its probably still flashing a code, but your CEL won't light up. That happens a lot.
ok i pulled up the carpet and checked the code. it blinks once, and repeats every 2-3 seconds. looks to be a code #1 which is oxygen sensor #1...
I only have one o2 sensor on this car right? I just replaced the sensor in the header.
Lifeeater46
Nov 10, 2006 11:48 PM
Junkyard2000
Jan 10, 2006 07:47 PM
