tune up- what are some good spark plugs to get?
Old Oct 10, 2002 | 01:13 PM
BlackAC99's Avatar
Default tune up- what are some good spark plugs to get?
what are some good spark plugs to get to put in my 1999 integra GSR?
Old Oct 10, 2002 | 01:22 PM
-Whitey-'s Avatar
Default Re: tune up- what are some good spark plugs to get? (BlackAC99)
ngk-r with ngk's 8mm blue wires
Old Oct 10, 2002 | 02:26 PM
BlackAC99's Avatar
Default Re: tune up- what are some good spark plugs to get? (One Honda)
do u know how much they are and where i can get them?
Old Oct 10, 2002 | 03:21 PM
lazy bum shaughn's Avatar
Stock. I think Hondas use NGK, not sure.
Old Oct 10, 2002 | 03:27 PM
sleeprhatch's Avatar
stock spark plug wire and plugs are the best, hands down
Old Oct 10, 2002 | 03:53 PM
hoya_10fintec's Avatar
Default Re: tune up- what are some good spark plugs to get? (sleeprhatch)
Old Oct 10, 2002 | 06:38 PM
3rdGteg's Avatar
Default Re: tune up- what are some good spark plugs to get? (hoya_10fintec)
Those expensive spark plugs called Denso Iridium or something(don't know if they're any good though, but they better be if you're gonna pay like 35-40 bucks a set) and some NGK wires should be cool.
Old Oct 11, 2002 | 10:17 AM
exactvox's Avatar
Default Re: tune up- what are some good spark plugs to get? (3rdGteg)
Denso is good, but only lasts about 10k or actually depends on your setup. I had it in my acura, starts to fade out towards 8k range. Good sparks, but I prefer NGK. I use NGK BCPR7ES -11 on my turbo setup in my teg, but I'm running turbo and gapping those plugs around 0.030-0.032. These run about around $2.00 each at my cost, think retail was around $4.00 each.
Thanks,
Jay
Old Oct 11, 2002 | 12:44 PM
Tweakmeister's Avatar
Default Re: tune up- what are some good spark plugs to get? (exactvox)
gapping is important, make sure the plugs are gapped to the right spec for your motor.
most people run the copper ngk plugs (have to replace them sooner), and stock wires are just about the best out there (espcially for the money).
my next set of plugs will be Silverstone plugs...want to give them a run.
Old Oct 11, 2002 | 02:21 PM
3rdGteg's Avatar
Default Re: tune up- what are some good spark plugs to get? (Tweakmeister)
Don't them NGK's come gapped to manu. specs already? At least that's what it says.
Old Oct 11, 2002 | 02:24 PM
ls_vtec_b18a1's Avatar
yea they come pre gapped just put them in and you're off
lilo_goki
Oct 26, 2007 09:27 AM
rdeezy78
Jan 22, 2006 11:45 AM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
hybrider
Apr 25, 2002 06:44 AM
