fuel pump fuse: cant located it
Old Oct 10, 2002 | 01:04 PM
cr00klyn718's Avatar
Default fuel pump fuse: cant located it
i got a 94 civic cx with a b18c1....and i cant find the fuel pump fuse....
Old Oct 10, 2002 | 01:08 PM
-Whitey-'s Avatar
Default Re: fuel pump fuse: cant located it (cr00klyn718)
i got a 92 civic cx with a b16a....and i cant find the fuel pump fuse....
Old Oct 10, 2002 | 01:30 PM
Perfectionist's Avatar
Fuse #12 or #24. 15 amps.
Old Oct 10, 2002 | 02:12 PM
Default Re: fuel pump fuse: cant located it (Perfectionist)
oh yeah the reason why im asking because i wanna do a compression check myself and in my helms it says u need to dissconnect the fuel pump fuse...but nowhere in the book that it shows me where the fuse is located .
Old Oct 11, 2002 | 02:55 AM
Mista Bone's Avatar
D Tranny Guru
in the underhood fuse box, pull the ECU/Backup fuse. This kills the ecu so the injectors don't fire.
Old Oct 11, 2002 | 03:09 AM
Chiovnidca's Avatar
Default Re: fuel pump fuse: cant located it (Mista Bone)
It also disables the ignition so you don't fry your coil.
Old Oct 11, 2002 | 01:54 PM
Default Re: fuel pump fuse: cant located it (Chiovnidca)
but if i take the ecu fuse out and disable the ignition..then i wouldnt be able to crank the motor like im suppose to....too check the compressions..or am i wrong?
Old Oct 11, 2002 | 02:04 PM
Chiovnidca's Avatar
Your wrong. The ignition system is seperate from the starter.
Old Oct 12, 2002 | 10:59 AM
thanks...so the motor should still crank right
emgjsdk1
Oct 21, 2010 09:47 PM
vargas
Sep 4, 2008 09:43 PM
fastludeh22
Dec 21, 2003 08:50 PM
13BT
Sep 4, 2003 11:27 AM
Blown90hatcH
Aug 1, 2003 04:41 AM
