Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Help me figure out this issue!! PLEASE?? (06 Civic EX)
Old Mar 9, 2012 | 12:42 AM
DBada FM's Avatar
Default Help me figure out this issue!! PLEASE?? (06 Civic EX)
I have a 06 Civic EX coupe and when the car was purchased(used), it had a knocking sound coming from the front suspension area whenever I would drive over speed bumps, uneven roads, etc. Its sounds and feels like the strut was bottoming out. My first instinct after quickly checking things through was to replace the struts. So I went and bought some KYB Excels and replaced the old stock struts. After installing everything back on, the same symptoms still plagued the car. Now, I'm thinking that it might be the lower control arm bushing but after inspecting both side of the bushings, they only have minimal cracks. From my experience, minimal cracks like that wouldn't cause the struts to rebound so harshly as that. Or am I wrong? Let me know if anyone here has had a similar issues and if you could help me point me to the right direction onto what is causing this problem.
Old Mar 9, 2012 | 06:47 PM
DBada FM's Avatar
Default Re: Help me figure out this issue!! PLEASE?? (06 Civic EX)
bueller?
Old Mar 10, 2012 | 01:02 AM
vladd's Avatar
I know that the bump stops were a somewhat common problem on Si's, don't know if it applies to the lower trims as well. My '08 Si front left strut would make a popping sound over bumps at low speed, if the steering wheel was turned. I ended up driving it that way for 3 years and it never got worse. Replacing only the strut wouldn't fix the issue, if the bump stop was reused.
Old Mar 10, 2012 | 03:28 AM
lazlong's Avatar
Not replacing the top mounts can damage the struts. I destroyed a set in 1 day because I didn't replace the top mounts. I have a 2001 but, it's the same principle.
Old Mar 10, 2012 | 08:29 AM
DBada FM's Avatar
That's the thing though.. the old struts I replaced were still good ( no leaks & rebounded fine compare to the new KYBs ). But I replaced them anyways since I've already purchased them.
Old Mar 11, 2012 | 11:24 PM
vladd's Avatar
My strut with the popping sound didn't leak either. I was going to replace the bump stop, but ended up getting coilovers instead.
Old Mar 12, 2012 | 04:02 PM
k24z7's Avatar
I had a 99 si that made a knocking sound whenever I went over bumps and my first thought was also the struts. Then I found out I had a couple broken engine mounts. Fixed the mounts, fixed the knocking.
Old Mar 12, 2012 | 10:57 PM
DBada FM's Avatar
How many miles was on your Si when this happened? I wouldn't think that it would be the case since the car barely has 90k..
Old Mar 13, 2012 | 07:40 PM
k24z7's Avatar
About 150k.
You did buy it used, so you never know what it's been through.
Old Mar 14, 2012 | 01:10 PM
DBada FM's Avatar
I've checked all the engine mounts and they all look good. My integra's mounts used to look worse and it didn't have the same symptoms as I'm getting with this car.
I'll probably replace the front lower control arm bushings and see if it goes away. But it's weird though, the car only has 90k and I would think that the life of the OEM bushing would last longer than that.. maybe Honda's quality isn't the same as it use to be?
DJKAY
May 27, 2010 12:06 AM
yuning83
19
May 1, 2007 07:33 PM
1994 Honda Civic EX
Jun 3, 2005 06:02 AM
ImportechPerformance
Aug 27, 2002 08:13 AM
