garage sale. del sol integra civic etc
Old Mar 8, 2012 | 11:06 PM
raverx3m's Avatar
Default garage sale. del sol integra civic etc
all items are in order according to images
prices are pretty firm
meet in lynnwood bestbuy or barnes&noble or alderwood mall
all items are sold as is, i inspected them myself and whatever is damaged will be listed, but its your responsibility to inspect them as well...
TRADES or partial trades im looking for:
s2k(s2000) seats black with no rips
del sol leather seats with no rips
del sol floormats in mint condition
b18c5 type-r motor parts( complete head and/or complete block) in working condition
konig retracks or rota track-R 16/17 inch with tires 4x100 lug pattern ( no bold tires), rota subzero,racing hart cp-035r
itr red valve cover in good condition
some good headers for hi comp gsr
2.25 inch exhaust midpipe.
carbon fiber hood or trunk for del sol
SMALL LAPTOP
205/40/17 or 215/40/17 tires
HAVE ANYTHING ELSE FOR TRADE EMAIL ME WITH PICTURES. no junk please
d series starter 40 dollars
d16y7 ac bracket(alluminum) 20 dollars
d15b7 ac bracket(iron) 20 dollars
d 15b7 driver side engine mount bracket 10 dollars
d15b7 lower alternator bracket 10 dollars
d15b7 crank timing belt gear with spacers 10 dollars
b series integra DC forks 20 dollars both
P06 virgin manual ecu 60 dollars
p28 obd1 ecu pigtail
bitwriter best offer
2 auto tranny shift solenoids from d series 20 a piece came off working cars
integra hazard and rear defroster buttons 10 for both
98 civic horn 10 bucks
map sensor 20 each have 2
evap purge solenoid 20 each have 2
d16y7 crank fluctuation sensor 20 bucks
obd1 honda clock spring with cruise control wires uncut and not damaged 20 bucks
dc integra rear speaker covers 10 bucks
pair of PPI crossovers good quality 40 dollars
trunk pop switch with pigtail 5 bucks
ALL SPEAKERS TESTED AND WORKING
JL audio TR series 6.5 components 50 bucks about a year old
MB quart 5/4 components missing crossovers 40 bucks
stryke audio 7 inch midbass carbon kevlar cone used for about 2-3 weeks barely broken in 40 dollars
infinity 4 inch coax speakers 40 dollars
pair of 97 civic tweeters 20 bucks
pair of 95 civic AR tweeters 20 bucks
556UW universal remote start module 40 dollars BNIB
3 B series engine mounts (3 holes) 40 each not blown
set of del sol engine mounts( tranny, rear and driver side) 80 dollars for set
rear view mirror 10 dollars
GSR intake manifold bracket 10 dollars
d series intake manifold bracket 10 dollars
pic3
legend brake calipers missing brackets 10 dolars both(need cleaning)
P28 OBD1 harness UNCUT and no broken wires fresh tape and wired in OBD2 and OBD1 injector pigtails
( wires are not cut) obd2 connectors are soldered on properly no hack job, O2 sensor wire moved, ready for B series swap. 150
P72 GSR OBD1 wire harness with OBD2 injector clips also soldered 100.
enkei 17 inch wheels 50 both one almost brand new tire other is bad
integra DC front hubs(no pads no disks) what you see is what you get 40 both
motegi 16 inch wheels bad tires 50 both
DEL SOL VTEC shift linkage( you need this for B series swap) 120
del sol rear window complete assembly with working motor( i will test it when you buy) 100
B16 AEBS intake manifold 150
GSR intake manifold 80
GSR fuel rail with OBD2 injectors 50 dollars willinclude with either manifold for 40 dollars
brand new d15y7 water pump with gasket 20 dollars
TD44u b series vtec distributor 50 bucks not sure whats missing
kuhmo izen snow tires 60 dollars
d15b7 exhaust manifold with working O2 sensor 40 dollars
del sol frost white rear window trim 60 dollars
del sol milano red fresh paint rear window trim 100 dollars
d16y8 valve cover 40 dollars anodized orange
brand new del sol hood still in package 160
brand new mislabeled d16y7 OEM HONDA valve cover gasket 15 dollars
sony 2 chanel amp 80 dollars
COMPLETE jdm D15 non vtec head its complete 140 or 160 with exhaust manifold
del sol fuel sending unit with low fuel sensor 20 bucks
del sol a pillar/vizor set 50 dollars
rear speaker covers and center piece 340 dollars
rear compartments and side covers 50 dollars
glow gauges missing dimmer 20 bucks
DC front upper tie bar(shock tower bar) 60 dollars very good condition
white trunk lid and targa top holder with brackets snd shocks 80 dollars or 40 for trunk lid alone
complete 93 del sol dash 100 dollars
b series cam gears 10 bucks
[hr]
Old Mar 11, 2012 | 10:19 PM
raverx3m's Avatar
Default Re: garage sale. del sol integra civic etc
more parts
TRADE
pass side front lower control arm i want your old one with bown out bushings and a set of rear LCAs bushings dont matter
im upgrading to urethane bushings and hate to waste a barely used control arm so if you need one...
set of NON ABS axles that are also good no clicking or leaks i want you ABS axles in exchange.
td4u vtec dizzy dont know if igniter or coil works. never tested 50 bucks
d16 brand net timing belt cover never used 10 bucks
SRS unit from 94 del sol 10 bucks
d15b7 brand new water pump and seal 25 bucks
small can brake master cylinder with extra can( its nice and clean if yours is yellow) 25 bucks clean no leaks
big brake upgrade kit( big can master cyl, prop valve, and brake lines) 80 bucks its clean no leaks
jdmeg6r13s
Nov 22, 2010 02:16 PM
amy
Northeast (Sales)
61
Dec 7, 2005 03:19 PM
