Do you have to use Weld lugnuts with Weld wheels?
Old Oct 10, 2002 | 12:55 PM
rolow's Avatar
Default Do you have to use Weld lugnuts with Weld wheels?
I just got my 13x8 Weld Magnum's and the warning label said to only use Weld lug nuts is this true?
I have the Axas from Inline Four will they work?
http://store.yahoo.com/twincamtech/axulraclugnu.html
The IDRC event is saturday and i want to run
Mike
Old Oct 10, 2002 | 01:13 PM
straightline's Avatar
Default Re: Do you have to use Weld lugnuts with Weld wheels? (rolow)
Yes you usually have to use the lug nut's made for the wheels because they are made specifically for the type of material the rims are made of.
Where did you get your Weld's from and how much did they cost?
Old Oct 10, 2002 | 01:32 PM
rolow's Avatar
Default Re: Do you have to use Weld lugnuts with Weld wheels? (straightline)
I just got an email from Weld and the wheel has two sets of holes and the 4x100 is set up to use stock lugs so I am good to go.
I got them from Versus in Arizona $600 for the wheels
Old Oct 10, 2002 | 01:42 PM
Chugger's Avatar
i was lookin for weld skinnies but i cant find a metric lug pattern?
Old Oct 10, 2002 | 01:59 PM
rolow's Avatar
Default Re: Do you have to use Weld lugnuts with Weld wheels? (Chugger)
I know they have them try the site
http://www.weldmotorsports.com/
Go to Wheels then Pro Drag then Import Magnum 4x100 15x3.5
Or Wil (exospeedAMcrx) he sells Welds
[Modified by rolow, 11:03 PM 10/10/2002]
Old Oct 11, 2002 | 08:29 AM
badCRX's Avatar
New User
My friend Chris can get them for you. He works at a shop called Wheel Warehouse that is tied with Weld wheels. He and another friend of mine have the fronts and skinnies already of the Magnum Import drag's. Give him a call at 816-421-0880. He can also help you if you need on those lugnuts and what you can and can't use.
robbyptown
Honda CR-V & Element
Mar 17, 2013 02:52 PM
jdm project
Oct 27, 2012 05:33 PM
hale_image
Mar 14, 2005 11:44 AM
Lynx
Sep 29, 2002 10:44 AM
REVolution
Dec 10, 2001 05:12 PM
