Car only blowing hot/cold no warm
Old Mar 8, 2012 | 06:17 AM
Echelon's Avatar
Default Car only blowing hot/cold no warm
I haven't had a whole lot of time to open it up and look around but I wanted to see if anyone has had this issue before.
My car will blow cold air when it's set all the way cold and hot air when it's set all the way hot. But if I try anything in between it will just blow whatever I had it on previously. So if I had it blowing cold and switch it to middle it will keep blowing cold, if I had it on hot, switch it to middle setting it will keep blowing hot air.
Do you guys think it might just be my climate control module?
This is on a 2000 hatch btw.
Thanks
Old Mar 8, 2012 | 05:17 PM
dlstech's Avatar
Default Re: Car only blowing hot/cold no warm
The cables or whatever controls the movement might be loose and only be about to stay open or closed and not in between. You have to get in there and look.
Old Nov 6, 2012 | 11:54 AM
Echelon's Avatar
After living with it for a while it's pretty annoying in the winter now. Mine is a 2000 so it has the electronic climate control. I still cannot get this thing to blow warm air. PITA. Anyone?
chevisregal
11
Mar 8, 2024 04:19 PM
Lithel
Oct 3, 2023 12:51 AM
NoEx00
Mar 8, 2007 07:31 PM
Prevail
Jun 22, 2003 06:33 PM
