TPS cuts out at full throttle
so i was on a dyno doing a pull with vtec set at 6500 and there was no problems. after pulls at 6500 i set vtec at 5500 and at 5800 rpms the TPS cuts out for barely a second, but its was my last pull so i couldnt see if it did it again. when i left i gradually got on the pedal from nothing to WOT, there were no problems. but after doing a 3rd gear pull it happened again. no codes set, and havent had a chance to see if there are and pending codes. LEAN PROTECTION IS OFF. and dyno was 4th gear. and tuning is mostly done by me.
i have my map and the datalogs of the pulls below. dyno 3 is vtec at 6500 and 4 is at 5500. and only adjustments to the map while on dyno was fuel on low and high cam
thanks in advance
link below is to the same thread but at clubrsx which has the map and logs
http://forums.clubrsx.com/showthread.php?t=814160
thanks in advance
schuessler28
12
Aug 2, 2005 07:35 PM
