REAR DISC CONV ?
Ive searched this and still can't find an answer. I have rear disc swap from a 92 integra. I know you suppose to use the ones from a 94-01 but i got these for a steal. $60 for both cables included. Is there anyway I can use these on my 91 ef dx 4dr hatch? If so what do I need to do to them to make them work? (cut my trailing arms and weld to the tegs?
The differential rear brake conversion can cause people a lot of headache I for one can lighten your day by telling you that the equipment you have in your hands is the right equipment for the job. The other preception is that going to a trim that wasn't suppose to be just give a piece of evidence that one think it were grand'er to give quality over matter the rubber feeling of new sensation.
I used 92-93 Integra rear trailing arms and brakes on my hatch. No problem with install or alignment but I've read that it adds a little bit more track width over stock.
90-93 integra rear discs are the most ideal because it does not add track width. 94-01 integra adds .25" width on each side, but they still work fine.
You might have issues with your e-brake cables though. Do some searching and make sure you have the right length cables before you start. Having no e-brake after a disc swap gets old real quick. I know from experience.
Things to check before you swap those onto your car:
Does it need brake rotors or pads?
Condition of wheel bearings?
Condition of soft brake lines?
Condition of trailing arm bushing?
Replacing any of those is easier while the trailing arm is off the car.
Thanks guys. Your input helps alot. Doing the swap this weekend for sure. Will post picks of swap and how it turns out. Also it came with cross drilled rotors. Lucky me.
I used eg6 si-r rear disks on my ed9. Alignment was a little off, but still within specs. The brake cables hung a little bit, but not enough to drag or catch on anything.
Well I've already said where I got mine from. Bought it from Hmotorsonline. Had it for about 6 years.only thing I changed was the MC because the then 16 year one had failed. And I swapped it out for a 91 civic ex one.
1989 civic si hatch
stock front disc
stock brake booster
15/16 civic EX master cylinder
4040 prop valve
ATE Super Blue brake fluid
I can lock up all 4 wheels on demand.
stock front disc
stock brake booster
4040 prop valve
