Will 92-95 civic ex manual dash harness working on 92 hatchback si
Old Mar 6, 2012 | 06:01 PM
nkmndz's Avatar
Default Will 92-95 civic ex manual dash harness working on 92 hatchback si
My si dash harness got a short when the o2 sensor melted all the way to the main relay. I tried to fix single wires but thought it would be better to swap out complete harness. I can't find a si harness and thought it would be easier to find an ex harness. But can anyone confirm what I need to do to put it in? Also what I need to do to make the rear harness work as well. Someone that has done knows that it's a bitch to remove everything so want a for sure good answer before I start.
Old Mar 6, 2012 | 06:18 PM
1slowRicer's Avatar
Default Re: Will 92-95 civic ex manual dash harness working on 92 hatchback si
You should start taking out your whole dash and interior if you want it clean, carpet and all of that, Ex harness should work, its what a eg SI uses I think. I also have to do the same to my Lx, has a short somewhere
Old Mar 6, 2012 | 07:11 PM
nkmndz's Avatar
Thanks I was planing on doing all of that. Just want to make sure cause it's a lot of work
Old Mar 6, 2012 | 07:57 PM
nkmndz's Avatar
Bump
Old Mar 6, 2012 | 09:32 PM
nkmndz's Avatar
Bump
AZN89
Mar 17, 2012 11:53 AM
jdmunlimited
Mar 10, 2012 05:44 PM
goldenchild707
Aug 9, 2011 02:30 PM
