HONDA/ACURA SFWD , PARTS,MOTORS ,ETC.....
HEY WHATS UP I BEEN IN TO HONDAS FOR A WHILE AND IM TRYING TO GET OUT FOR A WHILE NEED TO GET THINGS GOING IN LIFE BEFORE I CONTINUE WIT THE HONDA GAME SOO IL SELLING SOME PARTS....
*GOLDEN EAGLE SLEEVED LS BLOCK-81.5MM NEW NEVER RAN,ITR WATER AND OIL PUMP , NEW TNSIONER ,AND SEALS ETC .$-950
*GSR TRANS- M FACTORY LSD, SYCNCHROTECH CARBON SYNCHROS AND OEM SEALS AND BEARINGS NEVER USED $sold
*SFWD FUEL SETUP- USED FOR START UP AN DYNO ONLY_DUAL BOSCH 044 PUMPS AND PRE FILTERS, AEROMOTIVE FPR AND ELDEBROCK FILTER FIREWALL MOUNTED, ALL FITTING AND RIAL WITH FITTINGS NYLON BLACK SERIES LINES AND ITS 10-AN FEED 8-AN RETURN, RELAYS,FUSES,AND GROUNDS INCLUDED AND TOP HAT FOR STOCK TANK WITH AN RETURN FITTING ..$1000.00
*TILTON RELEASE BEARING- FULL KIT WITH FLOW VALVE GOOD CONDITION SLIGHTLY USED -sold
*WILLWOOD BRAKE BOOSTER DELTE- FULL KIT AND EXTRA PARTS IN BOX STILL ALL STAINLESS LINES FROME EVER CALIPER TO PORPRTION VALVE AND TO THE MASTER CYLY...$sold
*BATTERY RELOCATION WIRES WITH COPER CONNECTOR ON THEM OFF INTEGRA ONLY USED FOR DYNO, ENGIN BAY TO BACK OF CAR THE BATTER LINE FROM SWITCH AND THEN GROUND WIRE-$100
*VALVE COVER WITH CATCH CAN- WHITER POWDER COATED B SERIES VALVE COVER WITH DUAL AN-10 FITTING ON FRONT TO MORROSO CATCH CAN ITS THE 1L CATCH CAN NOT HUGHE ONE -$sold
*75 MM TB- I GOT EDLEBROCK RACING THROTTLE BODY 75.MM WITH ADAPTER PLATE BOTH BRAND NEW IN BOX AND HAS 3 WIRE SENSOR ON IT ALREADY FROM FACTORY-$300
*5" PORT COMP AUTO METER TACH WITH RED SHIFT LIGHT VERY GOD CONDITION AND HAS BRACKET FOR MOUNTING -$100
*DTR DRILLED SLOTTED ROTOR FRONT AND REAR HAVE 2K ON THEM NOT LIP OR GROVES MINT $75
*FAL SLIM FAN WITH HONDA OEM PLUG-$50
*FLP SHIFTER- MINT USED FOR 2K MILES WITH GSR SHIFT **** CLEAN ALSO -sold
*ITR SHIFT LINKAGE GOLD WITH ENERGY SUS. BUSHINGS RED-$125
*FULL RACE VACUM MANIFOLD WITH FITTINGS-BLACK -$25
*AEM BOOST SELINOD -$SOLD
*FIC INJECTORS WITH RESISTOR BOX WITH PLUG AND CLIPS 850CC-BARLEY USED -$200
*K TELER 3" TEST PIPE WITH ROTATING PLANGES -$50
*PWD JDM BATTERY TIE DOWN - PLOISH MINT -sold
*GORILLA LUG NUTS- EXTENDED AND OPEN ENDED SILVER 8 IN PACKAGE STILL 8 OUT AND STILL MINT -ALL 16-$sold
*3 BAR MAP SENSOR- GM 3 BAR WITH 3 WIRE PLUG AND CLIP-$ 40
*WIDE BAND 02- INNOVATIVE LC-2 GAUGE AND BOSCH 02 SENSOR -ALL SOFTWARE AND ASSECORIES- NEW -$ sold
* REAR DISCK CONVERSION EM1 - GOOD BEARINGS , ROTORS (RUST FROM SITTING )AND CAILIPERS $125
*B16 BUILT HEAD - SKUNK 2 EVERYTHING , VALVES, SPRINGS RETAIERS, PRO ONE CAMS AND PRO SERIES CAM GEARS , 3 ANGLE VALVE JOB -$SOLD
* ITR B18C SWAP-STOCK HEAD AND TRANS HEAD WAS INSPECTED AND TESTED BY HEAD GAMES AND BLOCK NUILT 13.5 COMPRESSION WIESICO, EAGLE H BEAM RODS AND ACLE BEARINGS ALL ASSELBELED BY SPEED-THEORY RACING DEVELOPMENT KNOWN GOOD SHOP TUNED MAKE 215 RAN FOR 500-600 MILES AND TOOK IT OUT AND SOLD EM1 SHELL ALL MOTOR WASNT FOR ME -$4500.00
TURBO KIT - ALMOST COMPLETE MISSING WASTGATE BUT CAN GET SYNAPSE 50MM, AFI MANI (LIFETIME WARRENTY)WITH DOWNPIPE , TREADSTONE FMIC WITH 2.5 INCH ALUMINUM PIPES AND 3PLY COUPLERS AND T BOLT CLAMPS ,50MM BOV TIAL SILVER, PTE TURBO 6776 RSP .70 AR COMP SIDE AND .63 AR EXHUAST BASICALL A 37R GOOD FOR 800WHP.....ALL LINES FEED AND RETURN AND OIL FILTER ADAPTER FOR FEED AND GAUGES...TURBO HAD 2K CAME OFF A EVO RUNNING 18 PSI BOOST TUNED.......IM SURE MISSING MORE SO JUST ASK - $2200.(TURBO ALONE WAS 1250 AND MANI WAS 950 WITH DOWN PIPE )
PIC COMMING SOON I SUCK AT LOADING **** ON LINE ....
EVERYTHING IS PRETTY FIRM BUT DONT HURT TO OFFER SO LMK TEXT OR EMAIL
EMAIL - THERRMANN89@GMAIL
TEXT 732 966 5732 - QUICKER RESPONSE AND PICS
