B20 in Ef. Won't crank need help it's my daily
89 lx. Mpfi conversion
B20b
B18a1 intake Mani and injectors, dizzy
B20 obd2 alternator converted obd0
Pr4 ecu
No crank at all. Just get one click from under the dash
Also when I crank tr brake light comes on.
Ecu had a solid red light. And the dash lights dim and flicker when ecu is connected
Totally lost. Please help
B20b
Pr4 ecu
Have you checked your main grounds? main relay? battery good? PR4 obd0 right? what dizzy are you running? If I remember correctly the a1's came in obd0 and 1.
Ok I'll double check Tom. Now the starter itself. I'm getting power at the signal wire terminal on the starter when the key is on. This is a brand new starter
I had same problem last night... ended up being the starter... put your car in neutral and then touch a wire from positive on the battery and then touch positiove on the starter if nothing happens then the starter is bad... smack that sucker with something then try and start with your key... if you get it to crank at all then the starter is bad. If not then fuse... ecu light staying on could just be its not grounded properly... if you were messing with it there is a chance you could have pulled a wire out of the back of the connectors or juse loosened it.
My buddy's GSR swapped CRX he just bought is doing the same thing.
It had a button not hooked up to anything already installed in a dash panel so we ran a hotwire to the starter terminal for now until he gets another harness, his is pretty hacked.
camtoe420
16
Jun 17, 2013 09:11 AM
drew2
Dec 3, 2005 11:51 AM
sidewayz32
21
Nov 15, 2005 05:06 PM
