90 honda accord transmissiong filter
Old Mar 6, 2012 | 02:28 PM
jdmcertified909's Avatar
Default 90 honda accord transmissiong filter
where is it located. im going to be dropping it to put new converter on it. i might as well change it. i know its inside the tranny i just need a diagram or someone to tell me where it is
Old Mar 6, 2012 | 06:39 PM
hondamark35's Avatar
Default Re: 90 honda accord transmissiong filter
Answers.com- Accord transmission filter
"not serviceable"
just do a drain and refill. If it helps you sleep better there are add-on filters for one of the trans cooler lines. Transmission suppliers/re-builders will require a shop to install one of these add-ons otherwise they won't warranty it. I suspect that means they work.
but, to answer your question it's inside the case. you must open up the case completely... may as well do a full rebuild at that point. A simple (even complex) diagram won't do if you're planning on this and don't know how already. pick up a factory service manual and follow it to the letter, or don't bother.
Old Mar 7, 2012 | 06:56 AM
"not serviceable"
well i just called a transmission shop and they told me where the filter is. i will be changing it along with the torque converter. torque converter clutch went to ****. it plugged up my pump strainer lol. i will keep updated
Brt123
Honda Accord (2013 - 2015)
Nov 5, 2018 12:14 AM
rotorbudd
Jan 3, 2013 01:11 PM
slooper
Nov 26, 2008 03:39 AM
timinarkansas
Oct 18, 2005 06:01 PM
e_r_i_c_
May 2, 2003 01:04 PM
