Need Help Swapping GSR cluster to JDM ITR cluster ASAP
Old Oct 10, 2002 | 11:24 AM
Fuuma0083's Avatar
Default Swapping GSR cluster to JDM ITR cluster ASAP
I just changed it and i see that the fuel drops down to empty. Do i have to reset ECU???
[Modified by Fuuma0083, 4:18 PM 10/10/2002]
Old Oct 10, 2002 | 12:17 PM
Fuuma0083's Avatar
Default Re: Need Help Swapping GSR cluster to JDM ITR cluster ASAP (Fuuma0083)
bump
Old Oct 10, 2002 | 01:16 PM
B00STeD's Avatar
Default Re: Swapping GSR cluster to JDM ITR cluster ASAP (Fuuma0083)
you have to swap the two "green pieces" that are on the backs of each of the clusters for your jdm itr to work right.
Old Oct 10, 2002 | 01:27 PM
Fuuma0083's Avatar
Default Re: Swapping GSR cluster to JDM ITR cluster ASAP (B00STeD)
i think its because its the wrong model year
Old Oct 10, 2002 | 01:39 PM
Leimokei's Avatar
New User
what year is ur gsr...mine swapped in fine...95 integra LS w/97 JDM ITR Cluster
Old Oct 10, 2002 | 05:33 PM
mugenracer's Avatar
Default Re: Swapping GSR cluster to JDM ITR cluster ASAP (Leimokei)
lay both clusters out and compare the circuitry sheet on the back of them, if they are different then your going to have to take your own off and fix it onto the ITR one in order to have the same plugs going to the same gauges/lights. i dont know how simple or hard this is to do, but i've seen numerous posts where the answers just reply that you have tp swap the back plastic circuit sheets about. try a search and see what you come up with.
EGRhatch
Sep 6, 2012 07:25 AM
sean2000gt
Northeast (Sales)
Feb 16, 2010 10:10 AM
ihavenocar
Northwest (Sales)
Aug 3, 2009 02:36 PM
